constant backfiring!
Old Feb 19, 2010 | 11:23 PM
fordman2267's Avatar
fordman2267
Question constant backfiring!
I have a 68 f250 with a 360 engine. it backfires out the passenger side often. I have hooker headers into cherry bombs without tailpipes. What could be the problem? Its too annoying to drive
Old Feb 20, 2010 | 01:35 AM
DarrellJ's Avatar
DarrellJ
Just to clarify: are you talking about engine shaking 'bangs' or popping through the exhaust?
Mine (see my sig) pops through the exhaust when cold or in-between, particularily on deceleration. If your truck doesn't have the cold air riser off the exhaust, it will contribute -- ie: a chrome open element air filter and headers.
If it's popping, in my case it's caused by a cold hearted 428 with headers, no heat riser, and fairly open exhaust.
If not, start with the basics: points, plugs, condenser, rotor, cap, timing. After that it's fuel - so fuel filter and carb. After that, I always drive the truck to my favourite mechanic and open my cheque book..
Hope that helps.
darrell
Old Feb 20, 2010 | 10:13 AM
mr.auto's Avatar
mr.auto
id say give the old girl a tune up, new plugs wires cap rotor, points condencer and see if that helps.
Old Feb 20, 2010 | 11:25 AM
Ford_Six's Avatar
Ford_Six
The 360 I rebuilt for my F250 had a cracked valve. It ran -ok- but did have a noticable popping out the exhaust.
Old Feb 21, 2010 | 12:33 AM
fordman2267
I do have the Pertronix igniter under the cap. had new plugs in with less than 500 miles on them. havent touched the carb or filter since I bought it last year. cap and rotor hasnt been touched either. new plug wires are on. truck is currently hibernating for the winter.I am just trying to get my priorities lined up for spring as to what I will check first. Thanks for the responses.
Old Feb 23, 2010 | 07:16 AM
Down Under 77 C/C's Avatar
Down Under 77 C/C
Wouldn't hurt to do a compreassion check, could be a sticking/burnt valve-only cost is time!
Cheers
Old Feb 23, 2010 | 05:37 PM
fordman2267
Smile Bundaberg rum!!
My brother in law lives in Brisbane. I also went to Australia for my honeymoon last year. Loved it and didn't want to leave. Anyway I think the trouble might be in the heads too. Running on unleaded fuel for too many years and I doubt the previous owner put in hardened valve seats. Thanks
Bud Kiebler
Jun 13, 2017 12:38 PM
Felix Perez
Dec 10, 2016 10:21 AM
joamariel
May 31, 2011 11:36 PM
Goker73
21
Feb 3, 2011 01:10 PM
coleaclark
37
Apr 11, 2008 02:07 AM
