What Trans Do I Have
Old Feb 19, 2010 | 06:07 AM
dahoopd's Avatar
dahoopd
Can someone tell me what trans is in my 2004 F150 5.4 (4x4)? I wasnt sure if they have a James Bond code name like the one in my Supercoupe, its a M5R2. The trans is shot in my truck and I was going to see what I could find for a replacement. Would one out of a 2005 5.4 4x4 work?
Also, I assume since the Transmission Malfunction light came on, there are stored codes. Can I remove the codes myself? Thanks for the help.
Old Feb 19, 2010 | 09:01 AM
shotgunz's Avatar
shotgunz
E-mail with competing site link sent.
Old Feb 19, 2010 | 10:24 AM
shotgunz's Avatar
shotgunz
Here is what each of the items are (position numbers):
  1. Exterior Paint Code
  2. Region Code (not listed)
  3. Domestic SpeciaOrder Code (not listed)
  4. Wheelbase Code
  5. Brake Code
  6. Interior Trim Code
  7. Tape/Paint Pinstripe Code
  8. Radio Code
  9. Axle Code
  10. Transmission Code
  11. Spring Code
Transmission Codes:
U – Automatic 4R70W (F-150, F-250)
E – Automatic E4OD (F-150, F-250)
M – 5 speed manuaoverdrive (F-150, F-250, Ranger)
D – Automatic 5 speed (Ranger)
T – Automatic 4 speed (Ranger)
And here's where you can get a copy of your window sticker:
http://services.forddirect.fordvehicles.com/inventory/WindowSticker.pdf?vin="YOUR VIN HERE WITHOUT THE QUOTATION MARKS"
Old Feb 19, 2010 | 10:58 AM
BirdmanStyll's Avatar
BirdmanStyll
strange, my transmission code says B, my axle code is 19, anyone know what i have? 5.4 4x4
Old Feb 19, 2010 | 12:02 PM
jstnromero's Avatar
jstnromero
you have a 4R75E transmission
Old Feb 19, 2010 | 02:46 PM
dahoopd's Avatar
dahoopd
Not to question your integrity or effort to help as I do appreciate it. But all of the info I have found shows the 4R75E being for 05-08 trucks.
Old Feb 19, 2010 | 03:11 PM
jstnromero's Avatar
jstnromero
hmmmmm.....i will have to do some more checking....is your truck the body style of the 04-08 trucks or is it the 97-03 style??
ON EDIT:
Model: 4R75E
Type: Four speed, Rear wheel drive, and 75(x10)lbs of torque
Years: '04-'07 F-150
Engines: 5.4L
Display: PRN(D)21 w/ overdrive lockout switch
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: B ('04-'05), Q ('06+), F ('06+ Mark LT)
Looks like it was called the B series transmission for 2004-2005 F150's and then it went to trans code Q for 06+ series trucks.
Just for future reference here are the transmissions used on 2004+ F150's (New Body Style)
F150 4.2/4.6 = 4R70E (700 lb-ft)
F150 5.4 = 4R75E (750 lb-ft)
150HD 5.4 = 4R75E(750 lb-ft) or 4R100 (1000 lb-ft)
Old Feb 19, 2010 | 09:10 PM
Djack04F150XL's Avatar
Djack04F150XL
My truck is a '04 4x2 and it has the 4R75E transmission. Your should have it also.
Old Feb 27, 2010 | 11:43 AM
dahoopd's Avatar
dahoopd
I hate to be a PIA but I have to put this out there again. I took my truck to a shop to a trans shop and although the guy didn't LOOK at the truck. He stated I have a 4R75W not the 4R75E as stated. How can I find out what I really have?
Will the trans be marked somewhere? This is driving me crazy. I am trying to find a good used one prior to dumping the cost of a rebuild or new unit for now if possible.
The guy gave me a quote of removing, fully rebuilding with 2/24 warranty and re-installing 1700. Does that sound right. Its a reputable shop and a lil old man that's been doing trans work since the dawn of time.
Old Mar 8, 2010 | 10:25 PM
FordTruckLover1999's Avatar
FordTruckLover1999
Call the dealer and tell them your VIN and they will give you your type tranny. Good luck to you, we are going thru this atm too. 04 FX4, with 104000 on the truck and the transmission is gone.
Old Feb 22, 2011 | 03:57 PM
BigD_ca's Avatar
BigD_ca
My sticker says "HB" under the TR. Is that mean it's a "B" and a 4R75E or something else?
I got a P0731 code come up so I need to know.
Thanks guys.
Old Feb 24, 2011 | 11:48 AM
BigD_ca's Avatar
BigD_ca
Anyone? My dealer is of no use.
tilliepeople
New Member Introductions
May 2, 2017 12:43 PM
chipper
Mar 21, 2017 08:03 PM
Nelson Arivett
1997 - 2003 F150
Mar 10, 2017 06:33 PM
Cigarette35
Dec 13, 2016 09:26 PM
spudlicker
17
Sep 28, 2016 08:36 AM
