what fluid should i use ????
Old Feb 19, 2010 | 12:30 AM
XBAJBUSX's Avatar
XBAJBUSX
ok i got my 95 f250 diesel with manual tranny i want to change the fluid in it what goes in it ??? atf fluid or gear oil and what brand should i go with ???? how hard is it can i do it at home ??? where is the drain plug and fill up plug because i would like to check the fluid too
Old Feb 19, 2010 | 12:58 AM
JCart's Avatar
JCart
Red Line MTF if it's a ZF5 plugs on the bottom of the tranny....fill plug is on the side...
jrc
Old Feb 19, 2010 | 01:03 AM
XBAJBUSX's Avatar
XBAJBUSX
oh its a 4x4 that will help ..
where i can get red line and how much i need ??
Old Feb 19, 2010 | 05:56 PM
XBAJBUSX's Avatar
XBAJBUSX
just did my oil change and check the fluid its little dark red i need to change it ..
XBAJBUSX's Avatar
XBAJBUSX
how many qts i need f fluid please help me out here im about to go shopping
Old Feb 19, 2010 | 06:05 PM
XBAJBUSX's Avatar
XBAJBUSX
and i have regular red trany fluid what do you guys recomand please help me out here
Old Feb 19, 2010 | 11:59 PM
JCart's Avatar
JCart
Have not change for some time but if iirc it's just under 4 so I put in four....should here in a manual somewhere...
jrc
Old Feb 20, 2010 | 07:02 AM
arkredneck's Avatar
arkredneck
i just used mobil 1 syenthic atf and i found if you take the gear shifter off it's you can just dump the fluid in it's only 4 phillips screws and 4 allen head bolts pretty easy
Old Feb 20, 2010 | 09:50 AM
XBAJBUSX's Avatar
XBAJBUSX
thanx for all the help just did the fluid change easy very easy didn't drive the truck yet will updated you how it shifts ...thanx all
Old Feb 20, 2010 | 11:39 AM
RRranch's Avatar
RRranch
Your owners manual says synthetic AUTOMATIC transmission fluid. You did right. You never use MANUAL transmission fluid or gear oil in the ZF transmissions.
Old Feb 21, 2010 | 06:10 PM
pjwoolw's Avatar
pjwoolw
Allot of folks run MTL in these trannys. Granted it a little thicker than there D4 or high temp ATF and not recommended. But in the warmer climates it's OK. In colder areas I would think twice. The Redline High Temp ATF is perfect for this application and the transfer case. No comparison to any other fluid I've used over the years. Schaffers is probably comparable but I've never run any of their products.
Old Feb 22, 2010 | 01:33 AM
donbrown's Avatar
donbrown
So ... pretty much ANY synthetic Transmission fluid (made today)will work ?
