1978 steering issues
Old Feb 19, 2010 | 12:29 AM
jamestw1977's Avatar
jamestw1977
I have a '78 f150 ranger supercab LWB 4x4 351M auto A/C. The problem is I have about 4 inches of play in the steering. I've been up under the front end and everything is good and tight. I adjusted the gear box, and it seemed to help a little but not enough. I've also checked the shaft from the wheel and it seems to be ok as well. Do I just need to invest in a new gearbox, or is there something else I could check out first.
Old Feb 19, 2010 | 02:21 AM
WyoExplorer's Avatar
WyoExplorer
My 76 has the same problem, a half a**ed mechanic told me aqt first it was the drag link, then in passing a week later told me I needed to replace my entire steering assembly, I doubt that, I'll let you know what I find out, a friend of mine who knows these truck in and out is supposed to stop by and take a look.
Old Feb 19, 2010 | 03:52 AM
460/5's Avatar
460/5
Zombie Survivalist
my 76 kinda has the same issue. put a new powersteerin pump on it, and it helped things out a bit, but i would recommend that your check your steerin box. have someone sit in the truck and wiggle the wheel while you listen to the gear box, see if you can hear the gears clinkin back and forth in there. should help you diagnose the problem. and while your at it, it really wouldnt hurt to throw some new bushings at your linkages.
Old Feb 19, 2010 | 12:16 PM
gearhed1971's Avatar
gearhed1971
I believe on '78s there is a cv style joint in the steering shaft.These create about an inch of slop at the wheel,coupled with other worn out steering components adds up to quite a bit at the steering wheel.Do you have a new rag joint?
DO NOT buy a cheap Chinese drag link,spend the buck on the Spicer. I thought I would save some $$ on the cheaper part,and the first time it went off road, both tapers pulled out of the link.And that wasn't even under any real abuse and 30" tires
Old Feb 19, 2010 | 12:28 PM
montana_highboy's Avatar
montana_highboy
Having only 4" of play at the steering wheel on an old Ford is not all that bad actually lol, but on a more serious note if you do narrow down the excessive play to the steering box don't waste your time or money on a "remanufactered" box from the chain stores, go with these guys here...Red-Head Steering Gears, Seattle WA - Red-Head Steering Gears Home...you'll be glad you did.
Old Feb 19, 2010 | 12:29 PM
jamestw1977
I'll check all that out. I have had 5 previous dentsides this one being the 6th, and I've never had this problem with any of the others.
Old Feb 19, 2010 | 05:55 PM
zaaac's Avatar
zaaac
I have heard that tilt steering has a bolt that comes loose in the column and causes sloppy steering. I need to check that myself.
Old Feb 19, 2010 | 10:12 PM
jamestw1977
O.k. Well I checked things out and there's no rag joint it does have a u-joint put it's tight. I'm sure I found the problem. Just before the gearbox there's a joint that appears to have a bushing in it and a cotter pin ran thru the end of the column if you know what I'm talking about maybe you can help. When the wheel is turned all the play is in that joint. Any idea if thats an easy fix, or any thoughts about it?
Old Feb 19, 2010 | 10:48 PM
WyoExplorer
do you mean the Steering Coupler?
Old Feb 19, 2010 | 11:06 PM
jamestw1977
I guess I never in my life had any steering problems before so I ain't really to sure.
Old Feb 19, 2010 | 11:12 PM
WyoExplorer
I ain't sure either, by looking at the diagram of the steering assembly, it looks like it's what your talking about.
Old Feb 19, 2010 | 11:30 PM
jamestw1977
so any ideas on a fix?
pgguru
May 16, 2014 01:38 PM
dieselsound
Dec 2, 2013 12:24 AM
greasemanicure
26
Sep 7, 2011 10:08 PM
WickedSharp
Jul 13, 2011 08:32 AM
dougas
Aerostar
Jun 4, 2002 06:20 PM
