DashDaq-XL
Old Jun 26, 2010 | 03:54 PM
  #61
bpounds's Avatar
bpounds
That looks good, Mark.
My OBD plug looks exactly like that, and when I first saw it I was certain it would bang my leg. But surprisingly it never has, and I have forgotten all about it.
Old Jun 27, 2010 | 05:38 PM
  #62
Sarge261's Avatar
Sarge261
Oh My Its Hot There !!!!!!!!
Old Oct 13, 2010 | 05:40 PM
  #63
otterlakepimp's Avatar
otterlakepimp
Originally Posted by bismic
Just received my "ProClip" parts. Wasn't cheap, but it mounts VERY well.
The DashDAQ comes with a "Dual T" adapter plate. This plate can be used with a variety of products. I found it to fit well with the ProClip products.
ProClip Mounting System*-*Device Holders and Dashboard Vehicle Mounts
These two parts are all that is needed from ProClip:
2 Prong (Dual T) Mounting Plate with Tilt Swivel - part # 215199 ($34.99)
ProClip Center Mount 2005-2007 Ford F-250 - part # 853546 ($29.99)
I also used the quick connects (called the move kit), but I do not think it is necessary (but it could be because these adapters provide a little bit of extra clearance for the cord). A "move kit" costs another $10.
This system mounts it just above the vent that is between the radio and the steering column. Easy to take on and off. Does not affect front windshield visibility.
Pictures tomorrow!!!
Thanks for the info, I ordered mine tonight
Old Apr 2, 2011 | 07:39 PM
  #64
Rob.D's Avatar
Rob.D
Originally Posted by 04Xcursion
Mark,
Have you played with any of the FICM voltage displays?
I have been doing some experimenting I think I may be on to something. I performed the 58V mod on a spare FICM I had and after the mod, no matter what the operating condition the main FICM voltage reads 13.625V. On the old FICM (which was going bad) I would see voltage displays all over the map ranging from about 6V up to 12.2V. Before I replaced the FICM I measured the output directly and found it to be in the 48V range when the FICM was warm, the DD was showing ~12V. Thus I now believe that to display proper FICM main voltage on the DD you must scale the signal by 4x and the maximum voltage readable is 54.5V.
If you have a chance to try this let me know if it looks reasonable. I can't right now because my FICM is over what I believe is the maximum.
Thanks
Did you ever come to a conclusion as to what you were reading in regards to FICM voltage?
Cowboy65
All Other Items for Sale
Jan 19, 2016 11:00 AM
user 708242442
2009 - 2014 F150
Sep 22, 2012 05:02 PM
astamp78
6.4L Power Stroke Diesel
15
Aug 30, 2011 02:43 PM
DidgeriDood
General Diesel Discussion
Oct 23, 2010 11:45 AM
motor-man
Jan 2, 2010 12:09 AM
