Sponsored by: Auxito
2001 f150
Old Feb 18, 2010 | 12:58 PM
crowe03's Avatar
crowe03
2001 f150
PLEASE HELP!!!
I have recently started feeling a putter and somewhat of a shake on my f150 when I let off of the gas. I have ran engine tests and the codes given were P1299 and P0304. I have checked and looked into the codes but there are many different things listed that could possibly be wrong. I am basically asking for some assistance or looking for someone that had the same kind of problem.
Old Feb 18, 2010 | 07:18 PM
fordtech08's Avatar
fordtech08
well the p1299 means you over heated it, did you notice the temp gauge in the red?, since you overheated it I'm going to suggest you do a compression test good chance you have a blown head gasket or a cracked head, is your coolant low?
Old Feb 18, 2010 | 09:08 PM
crowe03's Avatar
crowe03
I checked the coolant and the coolant is fine. I ran the reset test in an attempt to reset my sensor to fix the P1299. After the test was done when letting off of the gas it doesn't not have a putter to it while letting off of the gas. The only time the vehicle putters is when I am giving the vehicle gas. The putter is when giving the gas while driving although it isn't a constant putter. The putter isn't a shake to where its going to break necks but noticeable. I have had numerous suggestions of spark plugs, water in the coils, broken coils, on and on and on. Trying to work the problem best I can or get advice before I spend the bucks to get it looked at. Its the recession hahaha.
Old Feb 18, 2010 | 09:22 PM
fordtech08's Avatar
fordtech08
well plug 4 tends to get filled with coolant when there is a slight leak at the back of the intake, take a close look at the metal pipe going to the heater hose
fordtech08's Avatar
fordtech08
you should be able to get a light and take a look at that just have to move some hoses out of the way
slaughterhouse91
Jan 2, 2011 04:34 PM
jay586
2004 - 2008 F150
Nov 4, 2010 11:11 AM
7700f150
1997 - 2003 F150
Dec 7, 2006 02:47 PM
ritchie46
1997 - 2003 F150
Mar 9, 2004 08:53 PM
ritchie46
Modular V8 (4.6L, 5.4L)
Mar 3, 2004 12:22 PM
