IAT2 is here Page 32: Air Management System but I doubt that's a problem...read the explanation above and you'll understand why. Your IAT2 sensor thinks the air it's seeing should be hotter than it is, so it's setting a code. You're getting the EGR codes because of the delete kit. Without custom tuning to turn them off you'll continue to get them.
I'm wondering if that code getting him to go into limp mode. I'm just reaching here though, I wouldn't think limp mode would allow for 25 psi of boost, but it would make sense given the EGR code.
the egr valve is in place still, the liberator kit does not come with an egr block off.
You need to have it blocked off. EGR in place in of itself isn't a bad thing as mine is still in place, but it's blocked off, welded shut. You need to have those things done and then go with what's below.
Originally Posted by hotboygsr
would a custom tune get my boost back up where it should be?
Custom tune would eliminate the code that you are having and depending on your strategy flash that could be a big deal as to the affects of having that code on there.
my egr cooler delete eliminates the egr connection from the exhaust to the intake manifold. should i just get a block off plate or something to fill the hole where the egr valve sits?
You should leave the EGR valve in the manifold and hooked up to the connector. Get a custom programer to 'electronically' delete/defeat the EGR valve function. That will get you your boost back.
Not having the EGR valve connected, without a programmer, will continue to cause 'low' boost.
