Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
calibrating mics
Old Jan 20, 2003 | 01:04 AM
inliner's Avatar
inliner
Question calibrating mics
What's the correct way to calibrate the outside micrometers? I have the standards and the tool, but am not sure how to go about it.
Old Jan 20, 2003 | 03:06 AM
Torque1st's Avatar
Torque1st
Posting Legend
calibrating mics
Do you have the clutch type thimble on your micrometers?
Old Jan 21, 2003 | 01:50 AM
inliner's Avatar
inliner
calibrating mics
If the clutch type means the thing on the end that clicks when you tighten the thimble than yes.
Old Jan 21, 2003 | 02:24 AM
Torque1st's Avatar
Torque1st
Posting Legend
calibrating mics
Make sure your anvill and standard surfaces are clean. You can measure the thickness of a piece of fuzz with these things. Adjust your mike with the standard in place with the clutch to get even pressure for each end of the range and check to see how much the reading differs at each end. Use the little spanner wrench to adjust the barrel of the mike the average of the difference at both ends. In other words if one end reads .0002 big and the other end of the range reads .0004 big adjust the mike to read .0003 less (split the difference). If you can't get consistent results with the same reading every time something is wrong and you need professional service.
Hope this helps.
Old Jan 21, 2003 | 02:33 AM
inliner's Avatar
inliner
calibrating mics
Thanks for the info. I was doing it wrong. I was just snugging the mike to the standard and then moving the barrel to line up with the zero.
Fluid Power
Computer Chips & Tuners
Jun 12, 2007 08:30 PM
Lazy K
35
Dec 1, 2005 01:11 PM
adelyser
1978 - 1996 Big Bronco
Oct 10, 2002 01:48 PM
Competitor1
Dec 27, 2001 03:56 AM
fast_eddy
Jul 17, 2001 04:54 PM
