1978 - 1996 Big Bronco
Speedo Calibration
Old Oct 3, 2002 | 10:44 AM
adelyser's Avatar
adelyser
Speedo Calibration
Old Oct 3, 2002 | 11:13 AM
Harley Davidson's Avatar
Harley Davidson
Speedo Calibration
I have a 1978 Bronco. Putting in a 6 inch lift and it will have 35 inch tall tires, anyone out there know the proper combination for the gears on the end of the speedo cable and the gear in the t-case? Thanks in advance......
Old Oct 4, 2002 | 01:50 AM
Riso79's Avatar
Riso79
Speedo Calibration
The gears at the rear end wont make a difference, or in the T-case. You need to change the gear for the speedometer.
Old Oct 5, 2002 | 02:11 PM
Harley Davidson
Speedo Calibration
What the hell do you think I asked,"anyone out there know the proper combination for the gears on the end of the speedo cable" read, don't post if you don't know squat......
Old Oct 10, 2002 | 09:07 AM
grago87's Avatar
grago87
Speedo Calibration
i 'm about to put the same set up on my 87, just have to make the time to do it. but i have looked into the speedo prob. and if i found the right info i believe that a 16 tooth gear on the spedo cable should work for a 3.55 rear end. give me a couple of weeks and i'll let ya know.
Old Oct 10, 2002 | 01:48 PM
Harley Davidson
Speedo Calibration
Thanks much, i'm using a 456 gear setup with an aod tranny.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
