coolant leak?
Old Feb 17, 2010 | 08:11 PM
chapopistolas's Avatar
chapopistolas
Cool coolant leak?
so drivin down the road in my 05 6.0L with 41k miles on it and it starts blowing white smoke and temp goes up and alarms. im pretty sure its a coolant leak since the coolant was empty. is there a way to determine where its from? egr, head gaskets, etc.? dealer is sayin they have to replace the egr cooler then move on to the gaskets. is this true? lookin at alot of mula to fix especially if its one step at a time.
Old Feb 17, 2010 | 09:15 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
If the EGR is shot, it has to be fixed before the head gaskets can be checked.
You may still be under warranty with an '05...have the dealer check that
Old Feb 17, 2010 | 09:18 PM
blood's Avatar
blood
if you do not use a tuner its most likely the egr cooler.
Old Feb 17, 2010 | 09:43 PM
chapopistolas
but if i do have a tuner then its probably the head gaskets right?
Old Feb 17, 2010 | 10:07 PM
SteveBricks
FTE Emeritus
Not necessarily.
Pull the EGR valve out and see if it's wet....there are instructions on how to do that in the tech folder sticky at the top of the page. If it's wet, your EGR cooler is shot.
Poorboy04
Jun 26, 2013 09:00 AM
Stealth94rttt
May 1, 2013 04:24 PM
KPBJJ
6.4L Power Stroke Diesel
15
Mar 16, 2013 07:56 PM
Mr. Sandman
Jan 13, 2012 06:13 PM
AndeyHall
Mar 9, 2010 11:40 AM
