Torque Converter Stud Broke off
Old Feb 17, 2010 | 07:12 PM
Fordenthusiasts's Avatar
Fordenthusiasts
On my 1995 F-150 with the 302 and 4r70w tranny, I was in the process of removing the engine to put some gaskets in it and when I went to take the nuts off the studs on the torque converter one of them wouldn't ever loosen up. It would turn but it would turn very hard. Upon closer inspection i noticed the the stud wasn't attached to the converter anymore. I can't really tell if I broke it loose or if it was already broken.
So my question is what should i do about it? Just leave it in the flywheel for balance purposes and hope that the other three will hold it, or is there someway to reattach it. I can't really tell how they are attached, they are not welded on, it almost looks like they were glued on with some sort of molten metal or something. I noticed while helping a friend put in a transmission in a chevy that it only used three studs anyway.
Any insight would be well appreciated. Thanks.
Old Feb 17, 2010 | 09:07 PM
pete17c's Avatar
pete17c
by your description it sounds like they were brazed on, kinda a high temp solder (I'm not sure as I have only worked on my 4sp / 302 combo) .. but you could try throwing a flame at it and see if melts .. may take a bit more than a regular propane torch, but you don't wanna get it red hot or even close as it may warp the fly wheel ..
also, think about calling a machine shop .. they may have better insight as to how to fix you problem ..
Old Feb 18, 2010 | 06:58 AM
subford's Avatar
subford
I think they were put on using a spot welder.
Old Feb 18, 2010 | 12:43 PM
Roanoker494's Avatar
Roanoker494
would not suggest running it with only 3 bolts. The chevy works with 3 because it is designed to use 3, they bolts are spaced accordingly. I would suspect that only only 3 bolts on a ford would result in a cracked flexplate, possibly worse. Advance auto list a new converter for about $100, may be something to look into.
Old Feb 18, 2010 | 02:31 PM
Eddiec1564's Avatar
Eddiec1564
I had one pop off before, after pulling the engine(tranny/TC still in truck), I just put the offending stud back in place on the TC and zaped it with a MIG welder. Took care of it and had no issues since. Just make sure you ground the MIG DIRECTLY on the TC or bad things will happen!
Old Feb 18, 2010 | 07:53 PM
Fordenthusiasts
Thanks for the replys. I didn't suspect it would be smart to run with three but just thought i'd ask.
I had thought about hitting it with a MIG welder but thought that it might throw off the balance of things. Do you feel any vibrations?
Anybody else have thoughts about using a MIG welder?
Old Feb 19, 2010 | 03:33 PM
Eddiec1564's Avatar
Eddiec1564
No vibs at all, I just put enough on to hold the stud in place. I did attach the MIG ground to a stud close to the area and did quick zaps and alow area to cool off for no warpage and over heating to occur.
Old Feb 19, 2010 | 03:48 PM
Jigger2020's Avatar
Jigger2020
I am a Ford tranmission tech, put a new or reman torque in the truck so you will not have any problem's down the road,Gigger
Old Feb 19, 2010 | 04:16 PM
Fordenthusiasts
I had thought about a new or re manufactured one but that is at least another $150. I know that it would be best to do that but if I can get away with welding I might try it.
Anybody else got an opinion.
Old Feb 20, 2010 | 02:42 PM
Fordenthusiasts
Anybody else have ideas about welding the stud back on or is a new converter in order?
Old Feb 20, 2010 | 04:05 PM
White 97 xlt's Avatar
White 97 xlt
If it were me, I think I would go with a new or reconditioned converter, if it could be welded quick enough to not burn the oil inside it might work.. But myself, I would be worried about cooking the oil and making chunks of crud that might stop up a passage somewhere, or warping the converter housing enough to cause it to fly apart out on the road somewhere...
But I have been accused of going overboard before...... But it is something to think about..
Old Feb 20, 2010 | 04:15 PM
Jigger2020's Avatar
Jigger2020
it does not matter to you what we say so just do what you want,I think you have enough info so go ahead.
Old Feb 20, 2010 | 05:11 PM
Fordenthusiasts
What do you guys think about putting JB weld on the broken stud and then tightening down the other 3 to squeeze the broken stud down.
Old Feb 20, 2010 | 05:47 PM
White 97 xlt
Yep GIGGER you're right!!!
Old Feb 20, 2010 | 05:52 PM
Jigger2020's Avatar
Jigger2020
I agree with you White 97,he could have had it fixed or replaced by now,Gigger
