Sponsored by: Real Truck
axle code unc
Old Feb 18, 2010 | 10:06 PM
_Rick_'s Avatar
_Rick_
Kid,
A small bit of information I found below. It's referring to a 2000 F250 but it's a start.
It seems to at least confirm that no axle code on the pillar sticker was semi normal back in the day and that the tag on your rear differential should answer your original question as I figured it would. I just hope the damn tag is still there. Sometimes mechanics or owners take them off when servicing the dif and forget to or just don't put them back in place where they belong!
Q) Is it normal to have no code on the VCF under the axle portion of the label?
A) Not "normal", but common on trucks built back then.
On an F-250, you know it's a 3.73 ratio and you know it's a Ford-design axle with 10.5" ring gear.
You can check the metal tag under one of the bolt heads on the dif to see if you have LS or open differential. If it's an SRW truck, it will have 3.73 gears. The tag will say "3L73" if it's LS and "3 73" if it's an open diff.
Rick...
Old Feb 18, 2010 | 10:51 PM
thedieselkid's Avatar
thedieselkid
i call the dealer up when i get a chance. I'm sure they got all the info if you give them vin number.
Old Mar 25, 2010 | 08:59 PM
zep065's Avatar
zep065
2nd Gear
im having the same problem on mine. No axle code on the door sticker. i have a 2000 f250, the metal tag on the diff itself (as far as i can tell) states that i have a 4.10 LS all though its hard to see the first number because of the bolt.
Old Mar 26, 2010 | 02:23 AM
redford's Avatar
redford
FTE Leadership Emeritus
If all else fails, Ford will send you a copy of the original window sticker if you give them the VIN.
In the case of the Chassis Cab, does Ford ever ship the truck without a rear axle?
Old Mar 26, 2010 | 02:35 AM
twags6's Avatar
twags6
The only reason I could see is for a railroad truck with custom narrow axles.
Old Mar 26, 2010 | 09:03 PM
mrblonde108's Avatar
mrblonde108
I just got my truck home but the tag is mucked up with grease. As soon as i get under there i'll post the numbers on the tag.
Old Sep 5, 2010 | 04:34 PM
thedieselkid
my rear tag:
3S 461 E
3L 73 105 9f25
On another note. My other truck (1999) ,if the tag is correct has limited slip in the rear but open in the front. Is this common practice???
Old Sep 5, 2010 | 10:21 PM
twags6's Avatar
twags6
You have a 3.73 limited slip (the 3L 73 part) 10.5" sterling axle.
Thats a normal practice. Having a LS up front can make for some interesting steering when the hubs are in. That's why you usually see an open or locker in the front.
Old Sep 5, 2010 | 10:37 PM
mrblonde108
what's a locker and what would happen with the steering if LS?? would it pull or something??
Old Sep 5, 2010 | 11:11 PM
twags6's Avatar
twags6
A locker is a differential that locks both axle shafts together. Some are automatic, others are selectable (off or on). The downside to this is its difficult to turn since both wheels turn the same speed.
A LS up front would give the same pull since it trys to stay locked up. It'll slip eventually though. I'm not sure exactly how it feels since I've never driven a vehicle with a LS up front.
66gpw
13
Apr 7, 2010 10:13 PM
unc6362
1983 - 2012 Ranger & B-Series
Sep 3, 2005 01:56 PM
toque
Apr 11, 2005 03:20 PM
unc23
1978 - 1996 Big Bronco
Jul 22, 2002 10:59 AM
