PSD Contest
Old Feb 17, 2010 | 04:32 PM
tjbeggs's Avatar
tjbeggs
Originally Posted by chicagodragon
do you mean unplug the hose or electrical? or same thing?
Unplug the electrical connector
Old Feb 17, 2010 | 05:54 PM
Action4478's Avatar
Action4478
Hey T, .. How does the map s work ?
Old Feb 17, 2010 | 06:26 PM
DRRXR's Avatar
DRRXR
Findings
Got the stand pipe out THANKS TIM
The base plate was missing two the of the elements pads, found them in the btm of the bowl. Cleaned it all out, found some pitting at the btm of the bowl.
Then checked codes
No present codes but had these memory codes
P0198 Eng oil temp circuit hi
P1282 Injector Control Press
Then the one for the Map sensor when I unplugged it last night. P0237 Boost CKT Low.
Any thoughts on the first two codes?
Old Feb 17, 2010 | 06:38 PM
DRRXR's Avatar
DRRXR
MAybe I need to unplug the fuel bowl heater. Maybe its about to short
Dunno. WAG
Old Feb 17, 2010 | 07:10 PM
Hussler's Avatar
Hussler
Dunno. WAG
No, it blows the fuse (bang) or it does not.
From this site .. 1995/1996 Powertrain Control System Electronics Diagnostic Guide - 1994-1997 Power Stroke FAQ
0198* EOT Engine oil temp sensor ckt high input No cold adv., fast low idle Open circuit, biased sensor, PCM, short to 5V
1282 IPR Excessive ICP pressure System fault Faulty IPR regulator (sticking), IPR shorted to ground
0237* MAP Turbo boost sensor A ckt low input Uses Inferred MAP signal Sensor, PCM (95MY) Open, short, sensor, PCM (96MY)
From the data I would visually inspect the IPR wires / connections, especially since you had a run-away condition.
Old Feb 17, 2010 | 07:29 PM
DRRXR's Avatar
DRRXR
Thanks Jim
I was thinking that I may have got some trash stuck in the IPR. I have been trying to kill some of the bugs and algea and all. I will check it out and post back. But now its brew time. The base plate on the bowl heater is flaking plated metal off, must be some cheap stuff. Dont know if any made it past the filter or not.
Reps sent.
