Sponsored by: Auxito
Transmission
Old Apr 29, 2010 | 09:41 AM
49 Ford F-1's Avatar
49 Ford F-1
I'm on F150online also. I have pics of my truck on there. I'm 97 on 37s. I hate to hear that about the 5 speeds. Has anyone said anything about the t56s? I know they have like on downside with i think a spindle or something, but is all I know of.
Old Apr 30, 2010 | 08:28 AM
Johnny Langton's Avatar
Johnny Langton
Originally Posted by tmoney8772
I have a 2000 f150 xlt 5.4l 4x4. it has the 4r70w. is it supposed to have a 4r100? its been acting up when shifting from 2nd into 3rd. it revs higher than normal and then bumps into 3rd, i dropped the pan and changed filter and tranny fluid which seemed to fix the problem but after coming back from a snowmobile trip it has been acting up again. any thoughts on if its bad or should be changed again. if it has to be replaced can i just do a swap from a 70w to a r100 or is there computer programming stuff or anything for that matter i have to change. thanks
Like Douglas Walker found-I'll bet you have a broken accumulator spring,or possibly a valvebody gasket with a torn/damaged corner.. You'll need a valvebody gasket, and fluid/filter at the least,possibly an accumulator spring.
JL
Old Apr 30, 2010 | 10:47 PM
RobbyMartin's Avatar
RobbyMartin
JL
Will this likely be the cause of a downshift issue as well? My truck revs to about 4000-4500 before it will kick down from 4th to 3rd if I do it abrubtly.
Old May 1, 2010 | 06:26 PM
Johnny Langton
I found a torn/damaged valvebody gasket when we fixed this on my friend's truck. It was leaking fluid from around the valvebody causing a pressure loss and made it flare on downshifts.
JL
Old May 1, 2010 | 06:45 PM
RobbyMartin
JL
Would a shift kit be a good option for me or would you suggest something different?
Old May 1, 2010 | 07:37 PM
Johnny Langton
No shift "kits".
If you want the shifts crisped up-I can tell you how to do it.
JL
Old May 1, 2010 | 08:06 PM
RobbyMartin
No shift "kits".
JL
I want that 4th to 3rd downshift corrected along with crispiness of upshifts.
Please tell me how to do it.
Old May 1, 2010 | 08:17 PM
Johnny Langton
The downshift problem is likely a bad valvebody to case gasket-Change it. If you want to firm up the 1-2 shift-remove the lower spring from the 1-2 shift accumulator, and leave the upper in place. If you want to firm up the 2-3 shift, remove ALL springs from the accumulator and reinstall just the accumulator in the bore.
JL
Old May 1, 2010 | 08:51 PM
RobbyMartin
JL
Do you happen to have any pics or illistrations that show me what I have to do. Or maybe point me to a place that can show me?
Old May 1, 2010 | 08:54 PM
Johnny Langton
TCCoA | TCCoA
Articles.
Transmission.
Transmissions 101.
Read. Learn. Do.
JL
jdog771
Jun 30, 2016 11:02 PM
lincolnboy73
13
Aug 17, 2012 04:41 PM
wats504
Feb 5, 2011 03:37 PM
bigbuick
1997 - 2003 F150
Nov 21, 2010 08:19 PM
jgbailey57
Jul 2, 2009 09:11 PM
