Input on 390
Old Mar 4, 2010 | 08:44 PM
terryf150's Avatar
terryf150
Talking
I am new to this site so if i mess up take it easy i am trying to find out about getting headers for a 390. it is in a 85 f250 that i am buying. does any one know if 460 headers will work. i would like to make this a prety bad motor. any info on this would help. this is my first big block and im ready for some power.
Old Mar 4, 2010 | 09:21 PM
85e150's Avatar
85e150
Welcome to the site.
460 headers will not fit. Different engine family. --IF it's a 390. Are you sure this is a 390? That would not be a factory installation, as the last year for the FE was 1976.
Check the FAQ's at the top of this forum. Look at all the forums in this section--each one for a different engine family.
BUT FIRST, go back to page one on this thread and read the links given in posts 7 and 8. JUST what you need to know to build a killer FE for your application.
FWIW you better double check everything about this truck if it indeed has had an FE swapped in. Don't buy a butcher job, and if it's a good job, think twice anyway, because it will be something of a "hobby" to keep it all straight when maintaining etc.
Good luck with it.
Old Mar 4, 2010 | 09:35 PM
galaxy666's Avatar
galaxy666
your best bet without spending a **** load of money would be get an air intake that is open and get quality wires and plugs
Old Mar 5, 2010 | 03:59 AM
jowilker's Avatar
jowilker
Last FE was installed in 76, engine bay changes made in 80. Without custom made, no apps for that.
Are you sure it is a transplant engine? 85s came with 351Ws, & 460s, I suggest you first verify which engine you have.
Post the VIN Bill can tell you what came from the factory in it.
John
Old Mar 5, 2010 | 11:28 AM
terryf150's Avatar
terryf150
thanks. yes it is a transplant. the truck had a deisel that they blew up. it will be a project truck. i do have a mechanic back ground just not with this engine. is it a good motor for a build? it will be driving acasuanly on the road but will be off road alot. that is what it will be built for. i am putting a 79 3/4 ton dana 44 straight axel under it. so it is mostley for fun.
Old Mar 5, 2010 | 06:53 PM
jowilker's Avatar
jowilker
The 390 is a damn good truck motor, highly sought after in the 60s & 70s trucks. A good setup 390 will run with the diesels all day long.
As prior, none were installed past 76, so anything that you do in that truck will have to be trial & error. Sounds like you like makin things work out.
guluk
John
Old Nov 17, 2010 | 10:13 PM
SaltySenior's Avatar
SaltySenior
1974 Ford F100 390FE
Well hello gents, took a long time to find you, but I'm thankful!
I bought TSoptich's F100 with the 390. Great kid, gave me a heckuva deal. Nice truck.
As he asked, I inquire a similar thought. I've already discovered 10000's of opinions on what to do with the engine, etc. So let's get down to brass tacks.
I'm looking to build up the 390 a little, Exhaust Headers, Intake Manifold, 4BBL, RV Cam, flush the oil, clean up pistons, valves, etc, replace all gaskets, full tune-up and then hope for improved gas mileage. I'm currently seeing about 6-9 MPG. I can live with 15-20. Can I ever expect to get that out of the 390? I won't be pushing it hard, no racing, no track, just pulling a trailer, Quad and going from park to park to have fun.
I've been told EFI will yield great results also, but opinions differ there as well. I'm a beginner in the restoration process, I intend to restore the truck to it's former beauty -beast- as he should be. The final step will be 4" lift, 33's and limited slip diff. I understand the C6 is an ironclad tranny. So do I stay with the 390 or move to a 351C,W, or that route. Good power, better economy.
Thanks for all the help.
Old Nov 17, 2010 | 11:05 PM
Tsoptich's Avatar
Tsoptich
well thank you saltysenior. I miss that truck already. but I got my 74 4x4. and I just traded my 390 out of it for a 300 inline 6 out of a 84 f150 with headers and an upgraded 4 barrel intake and carb. but thanks all you guys for the advice.
Old Nov 18, 2010 | 05:53 AM
jowilker's Avatar
jowilker
SS, Welcome to FTE and Ford truck ownership. My first thought, How much money are you prepared to throw at it to get 12 mpg, as that is about as good as it will get. The things you mentioned new will run about $12-1500.00 for parts. EFI twice that.
You can upgrade to electronic ignition and skillful tuning of timing & carb and get there.
What's your pleasure?
John
alloffroad
Jun 15, 2011 10:51 PM
Chad Shaver
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Apr 17, 2010 11:24 AM
jarmeister
17
Feb 25, 2006 07:31 PM
somethingurnot
Jan 15, 2004 05:10 PM
Steve 97439
Mar 22, 2003 03:51 PM
