Leaking T-19
Old Feb 16, 2010 | 02:58 AM
TomA92's Avatar
TomA92
Leaking T-19
When I first got my truck I noticed the transmission groweled in first gear. I checked the oil and it was way low. I filled it up and noticed it leaked a small puddle every time I stopped.
I have been topping it off once in a while ever since. It is hard to tell where it is coming from. At first I thought it was from the front, being a bad seal and possible bearing on the mainshaft. Today when I filled it I thought it looked like it is coming from the back. It is a four wheel drive so the transfer case is connected to the rear of the transmission. I doesn't seem to me that there would even be a seal there. The transfer doesnt leak a drop and has ATF in it. Is anyone familiar with this problem?
Tom
'86 F250 6.9 4wd
Old Feb 16, 2010 | 07:10 AM
Brimmstone's Avatar
Brimmstone
tailhousings on the t19 like to come loose over time. Don't ask how I know this.
Old Feb 16, 2010 | 07:56 PM
kenpobuck's Avatar
kenpobuck
I know that the connection between the t-case and the tranny on the c6 is open to the inside of the tranny. There is a gasket between the t-case and tranny. I had to buy gasket material becuase no one could find this gasket for me. I still think it was the sillycone I used on the second tranny that gummed it up and trashed it. I only use gaskets now. Might be that the t-19 is the same way and the oil is coming out there.
Old Feb 17, 2010 | 08:39 AM
TomA92's Avatar
TomA92
Thanks guys, this is what I was hoping. I did not see any obvious signs of loosness but I will get under there and check it out the next time I can get it over the pit.
Tom
tom6433
Oct 22, 2014 11:38 AM
esidneyw
23
Feb 13, 2014 06:51 AM
bigunit54
2004 - 2008 F150
Apr 29, 2011 08:36 PM
1954F250
Nov 7, 2005 04:59 PM
