Transfer case overfill
Old Nov 6, 2005 | 03:43 PM
1954F250's Avatar
1954F250
I went to change the transfer case fluid on my 1995 F150 for the first time (I am the original owner). I took out the fill plug first to check where the fluid was before I drained it. I was surprised when oil gushed out of the fill hole and onto my garage floor!
There were about four quarts total that I removed from the transfer case. The owners manual states the fill capacity is two quarts. When I refilled the transfer case, fluid started dribbling out of the fill hole just as I finished putting the second quart in.
I am confused as to how the extra fluid got into the transfer case. It could have been over filled from the factory. I thought that maybe it could have come from the automatic transmission if the seal between the two units was bad.
Has anyone else run into a similar situation?
Thanks, Kevin
Old Nov 7, 2005 | 04:57 PM
rclarke's Avatar
rclarke
The extra oil probably came from the transmission. There is a double seal at the input shaft of the transfer case, it may have failed.
Old Nov 7, 2005 | 04:59 PM
ford390gashog's Avatar
ford390gashog
the seal may have failed
f250mtnbikr
May 15, 2015 10:26 AM
Jason T
Jan 6, 2015 02:04 PM
adam10
Mar 15, 2014 08:06 PM
tomspear
Oct 12, 2012 11:18 AM
05victorylly
Mar 21, 2012 04:33 AM
