my oil pumps goin bad should i install a high volume pump or stick with the stocker????? Thanks.
hey my friend this question has been tossed back and forth many-many times
just wait for it -I think a stock one is better than a bad one-and clean or replace the pick up/screen/ tube e.t.c~~ most times that is why the pumps takes an early out
I say it all depends on the miles and how you drive the truck. It won't hurt to put in a HV pump but why spend the extra money if it's a.....say farm truck.
The stock pump is what I would get. There is not any need for high volume, but definitely not high pressure. The higher pressure will just increase the potential for leaks.
U are right, high pressure has to do with the pressure relief spring, and high volume does just that, flows more volume than stock. But the pump I posted a link to is both high pressure and high volume. Most pumps are either or, not both.
