oil pump
Old Feb 15, 2010 | 04:20 PM
87f150stepside's Avatar
87f150stepside
oil pump
my oil pumps goin bad should i install a high volume pump or stick with the stocker????? Thanks.
Old Feb 15, 2010 | 04:21 PM
zxwut?'s Avatar
zxwut?
The stock one is fine.
Old Feb 15, 2010 | 04:24 PM
jr32560's Avatar
jr32560
hey my friend this question has been tossed back and forth many-many times
just wait for it -I think a stock one is better than a bad one-and clean or replace the pick up/screen/ tube e.t.c~~ most times that is why the pumps takes an early out
Old Feb 15, 2010 | 04:28 PM
87f150stepside
why not install a high voulme?
Old Feb 15, 2010 | 04:56 PM
6CylBill's Avatar
6CylBill
I installed a hgh volume in mine. No problems at all. 40 PSI.
Old Feb 15, 2010 | 05:01 PM
zxwut?'s Avatar
zxwut?
Why install a high volume pump?
Old Feb 15, 2010 | 05:17 PM
6CylBill's Avatar
6CylBill
I believe in playing it safe. Just replace it with the stocker.
I did instal a HV pump in mine and I haven't experienced any negatives.
Old Feb 15, 2010 | 05:32 PM
lew52's Avatar
lew52
Just use the stock pump , theres no need for a HV pump unless you have a deep sump pan & are racing it .....Lew
Old Feb 15, 2010 | 08:25 PM
Hitokori's Avatar
Hitokori
well its going to be the same amount of work weather or not u use the standard or the high volume.....
i say go with the high volume dosent cost that more and it doesnt take any special modifications.... just a little oil pan persuasion
Old Feb 15, 2010 | 08:52 PM
BigBlueOx's Avatar
BigBlueOx
I say it all depends on the miles and how you drive the truck. It won't hurt to put in a HV pump but why spend the extra money if it's a.....say farm truck.
Old Feb 15, 2010 | 09:09 PM
hav24wheel's Avatar
hav24wheel
Go high volume, and high pressure..
If its a 302 use this one,Milodon 18800 - Milodon High Volume/High Pressure Oil Pumps - Overview - SummitRacing.com
That's the one I'm getting for mine.
Old Feb 16, 2010 | 04:12 AM
TexasGuy001's Avatar
TexasGuy001
The stock pump is what I would get. There is not any need for high volume, but definitely not high pressure. The higher pressure will just increase the potential for leaks.
Old Feb 16, 2010 | 05:26 AM
hav24wheel's Avatar
hav24wheel
High pressure/volume pump is only a 20-30% increase. So, if ur runnin 30psi it *might* jump to 39 psi.
Old Feb 16, 2010 | 07:33 AM
TexasGuy001
From what I understand a high volume pump and high pressure pump are not exactly the same thing.
Old Feb 16, 2010 | 07:51 AM
hav24wheel's Avatar
hav24wheel
U are right, high pressure has to do with the pressure relief spring, and high volume does just that, flows more volume than stock. But the pump I posted a link to is both high pressure and high volume. Most pumps are either or, not both.
