Need advice on SAS
Old Feb 15, 2010 | 03:45 PM
Shade's Avatar
Shade
Need advice on SAS
I have found a new junkyard with really good prices and a few 80-86 trucks and Broncos in it so I'm thinking about doing the SAS in my 84 but have a few questions.
1) which front axle is the best to use and which trucks/broncos have it? How can I tell what axle each truck has?
2) how do I order a lift kit for the truck after it has two different year axles in it?
3) should I wait to find a 1 ton front axle or is something like a dana 44 strong enough?
4) do the straight front axles match width's with my 9 inch rear?
I'm not going to have more than a 38" tire on the truck and I doubt I'll ever go rock crawling but I want to be able to run a locker up front and don't want to be limited by a weak IFS axle. The truck will be mostly for hunting and playing in the mud (I will climb a hill or ford a river if given a chance though) Thanks for your help on deciding which way to go, hopefully the weather will change and I can get back to work on her soon.
Old Feb 15, 2010 | 11:08 PM
86sixbanger's Avatar
86sixbanger
I'm guessing you have either an '84 F150 or Bronco....
1. best axle for you to use is a 78-79 dana 44 from a 1978-79 F150 or bronco.
2. Order a lift kit for a 78-79 F150 or bronco.
3.Unless you want to do some custom fab work to either convert your half ton to a leafsprung front or convert a dana 60 to a coil spring setup, the coil sprung dana 44 will be an easy swap and will be plenty strong.
4. yes the solid 44 will match your 9 inch's width.
Old Feb 16, 2010 | 10:53 AM
Shade's Avatar
Shade
Yeah it's and 84 F150 flareside. Thanks for the info.
Old Feb 16, 2010 | 11:33 AM
86sixbanger
no problemo.
Old Feb 16, 2010 | 01:21 PM
Franklin2's Avatar
Franklin2
Is the 79-down dana 44 straight axle that much stronger than a Dana 44 TTB? I will have to concede on possibly better tire wear on the straight axle, but I am wondering if it's worth it in the strength department.
The proper IFS is so easy to just bolt in. The 79-down will not bolt in without fabbing or a kit some places sell. I haven't researched what is involved in the kit or how much it costs.
Old Feb 16, 2010 | 07:17 PM
Shade's Avatar
Shade
I really don't know. I was told that if I wanted to run bigger than 35" tires or have a locker in the front end that I need to go with the straight axle because the IFS wouldn't hold up to the strain. I'm not going to get crazy but I'll end up with 350-400 horses, a locker at both ends, and 37 or 38" tires but I don't want to be stuck in the woods with a busted axle.
Old Feb 16, 2010 | 08:16 PM
Franklin2's Avatar
Franklin2
I have a dana 44ttb ifs in front of my 89. It has the diesel engine, 4.10's with a 4 inch lift and 35's, and I plow snow with it. It hasn't broken yet.
Old Feb 16, 2010 | 08:49 PM
Freaksh0w's Avatar
Freaksh0w
I know that a TTB Dana 44 will withstand anything with 31x10.50's from experience, lol, but that's not saying much. Mine is just spinning in mud, Franklin has a much better example. If you are going to do it, go all out on a Dana 60.
Old Feb 16, 2010 | 10:40 PM
Franklin2's Avatar
Franklin2
Yes, but he has a f150.
Old Feb 17, 2010 | 07:59 PM
86sixbanger
so he needs to decide, either put leafs under the front of his truck, or coil spring a dana 60.
Old Feb 17, 2010 | 08:27 PM
Franklin2's Avatar
Franklin2
??? He has a f150. The frame is different on the front compared to a f250, and he will have 16 inch 8 lug wheels on the front and 15 inch 5 lug rims in the rear.
Old Feb 18, 2010 | 09:49 PM
Freaksh0w's Avatar
Freaksh0w
Oh, well, if he already has an F150 with a D44 TTB, then I see NO point in going to a D44 SAS. It's not going to be anything over 5% stronger in the most extreme conditions.
You will end up with needing less front end alignments, though, lol. But TTB handles great on-road, and I think it does better off road.. just my opinion on the handling on and off road.
Old Feb 18, 2010 | 10:40 PM
86sixbanger
A solid axle is a real cheap lift compared to a TTB, as there are no center pivot points and camber issues to deal with.
I suggest that the OP goes looking in the offroad forum for a guy called 75F350, and look for his thread on how he swapped leaf springs and a dana 60 under the front of his bronco. As for the different wheels thing, he could very easily put a 10.25 out back and do 'er right with full one tons.
