<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TD vAlign=top align=left>P0503 - Vehicle Speed Sensor (VSS) Intermittent </TD><TD vAlign=top align=left>Indicates poor or noisy VSS performance. Vehicle speed data is received from either the vehicle speed sensor (VSS), transfer case speed sensor (TCSS) or anti-lock brake system (ABS) control module. </TD><TD vAlign=top align=left>
Noisy VSS/TCSS input signal from Radio Frequency Interference/ Electro-Magnetic Interference (RFI/EMI) external sources such as ignition components or charging circuit.
Damaged VSS or driven gears.
Damaged TCSS.
Damaged wiring harness or connectors.
Malfunction in module(s) or circuit connected to VSS/TCSS circuit.
After market add-on.
</TD><TD vAlign=top align=left>Monitor VSS PID while driving vehicle, check for intermittent vehicle speed indication. Verify ignition and charging system are functioning correctly</TD></TR></TBODY></TABLE>
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TD vAlign=top align=left>P0720 - Insufficient input from Output Shaft Speed sensor </TD><TD vAlign=top align=left>The output shaft speed sensor inputs a signal to the PCM, based on the speed of the output shaft of the transmission. The PCM compares this signal with the signal of the VSS or TCSS and determines correct tire size and axle gear ratio. </TD><TD vAlign=top align=left>
OSS sensor circuit short to GND
OSS sensor circuit short to PWR
OSS sensor circuit open
Damaged OSS sensor
Damaged PCM
</TD><TD vAlign=top align=left>Verify sensor signal output varies with vehicle speed. </TD></TR></TBODY></TABLE><TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TD vAlign=top align=left>P0722 - No signal from Output Shaft Speed sensor </TD><TD vAlign=top align=left>The output shaft speed sensor failed to provide a signal to the PCM upon initial movement of vehicle. </TD><TD vAlign=top align=left>
