Bill, I'll take a stab, from old memories of my first Slick. I see 2 possibilities:
1. The rear axle had stiffening rods welded to the bottom.
2. The rear springs had what I refer to as "helper" springs, an extra, shorter stack above the regular set of leaves.
Its the camper wiring harness...I knew that immediately...but I thought I would give others the chance to guess it first...LOL...Thanks for the msg Bill :-)
- cs65
I never knew that. I just checked your info in your gallery, very nice. I realize what Bill is saying about a camper special, but am I correct that majority of them had the bigger suspension and bells and whistles? Least ways that is how it appears down here in the south. I would really like to see what the 2 grill guards really look like from ford.
I should have remembered the additional wiring harness - my Camper Special had it, I harvested 2 or 3 in the last 5 years, and installed one in my Slick.
I have seen 2 types:
1. A single harness that includes wiring for both ammeter and ALT light, and oil pressure gauge and OIL light. This one includes additional wiring (for what I do not recall) all going through a single rubber grommet. Factory installed?
2. A separate harness for just the ammeter and pressure gauge. Dealer installed?
I have a 66 F100 Camper Special, it even has the factory grille guard you are talking about, first I have ever seen. Has all Custom cab stuff, extra gauges, door pockets, 352/COM, bed toolbox and extra gas tank on driver side.
Number Dummy, I worded that wrong and I knew better on what came on a Camper Special . It could lead some people to believe that I was saying those were standard on a Camper Special. Here is better wording.
"I have a 66 F100 Camper Special, it has the extra gauges correct for a Camper Special and is a 352/COM truck. Options above and beyond the Camper Special package include door pockets, bed toolbox and the factory optional grille guard on a painted bumper. An extra gas tank was added on driver side AFTER it left the factory."
Anyone have pics of what the grill guard looks like? I found a 66 250 in a local yard with a massive grill gaurd on it. Tall as the hood and wide as the truck. I was not positive that it was factory. Also had two bars going through the core support to the frame.
Adam
I have finally created a gallery and added pics of the Camper Special including the grille guard. It does have the support bars going through the grille. The grille is not cut for this that I can tell, standard aluminum grille.
C6TZ8307A .. GrIlle Guard / 1966 F100/350.
Original MSRP: $32.90.
1965 is slightly different (C5TZ8307A), as is 1964 (C4TZ8307PAK).
BlueBolt,
Didn't, however, the radiator support have to have openings cut to allow the grille guard supports to pass through to the frame?
BarnieTrk
