tilt collum
Old Jan 19, 2003 | 05:26 PM
shortbed1's Avatar
shortbed1
tilt collum
Hello everyone .
I have a 73 f100 that i am installing a tilt column out of a 79 f-150.
Is there anything i need to know about on the wiring ect.?
Any help would be appreciated.
Old Jan 19, 2003 | 07:14 PM
highboy_73's Avatar
highboy_73
tilt collum
the wiring for the horn ground is different.
You need to screw a piece of stiff bare wire between two of the screws and wrap it around the steering shaft. but other than that it fits right in. I hope this helps.
Old Jan 19, 2003 | 10:39 PM
Mil1ion's Avatar
Mil1ion
tilt collum
The wiring is different because the 79 Column neutral saftety/start switch is on the tranny but the 73 is on the Column.
Hazard lights are a problem too if I remember right.
I've never heard of the horn circuit being different UNLESS it has cruise control.
The Horn circuit is different if the truck has cruise.
defiantoutlaw
Mar 31, 2013 07:46 AM
oscajo
Feb 26, 2013 02:58 PM
Circle B
Jan 25, 2011 07:29 AM
NYBob
21
May 14, 2010 09:26 AM
hammerdn
Jan 12, 2004 11:27 PM
