fuel lines
Old Feb 14, 2010 | 04:48 PM
dieselkid's Avatar
dieselkid
fuel lines
the 2 main fuel lines running from the pump the selector switch. there is one line that is bigger then the other, i need to know and its my guess that the bigger line is the feeding line while the smaller line is ther return line??? is this correct
im disconnecting my 2 selector switches(im guessing that not wut stock truck have, i thought they have 1?) i have just found and have all 3 tanks out. right now im going to run 1 tank (the 3rd none stock tank) on my chassy cab and i need to know witch is the feeding line(i belive the fat line) and the return line(smaller line) so i dont make it backwords
Old Feb 14, 2010 | 05:00 PM
rupejosh's Avatar
rupejosh
you got it
Old Feb 14, 2010 | 05:40 PM
bnate's Avatar
bnate
IIRC both lines are 5/16" but the suction (feed) line has 3/8" ends where it hooks to the tanks and selector valve.
Old Feb 14, 2010 | 07:24 PM
starmilt's Avatar
starmilt
Not on mine the feed line is 3/8 and the return is 5/16. If you are not going to be running two tanks you dont even need a selector valve plumbed in.
Old Feb 14, 2010 | 10:30 PM
dieselkid's Avatar
dieselkid
i want to switch it to stock, so i want to run 2 tanks... going to bring it back stock
Old Feb 14, 2010 | 10:34 PM
starmilt's Avatar
starmilt
Gotha I would cut a piece of fuel line and clamp abolt in it to keep the ports you are not using clean.
KRinAZ
May 19, 2014 11:58 AM
Breaker Breaker 3-3
Mar 21, 2012 02:32 AM
ManicMike
16
Jan 9, 2011 10:00 PM
dieselbronco89
1978 - 1996 Big Bronco
Jan 6, 2011 06:19 PM
BruceN
Oct 13, 2001 08:45 PM
