1978 - 1996 Big Bronco
89 eletrical issue
Old Feb 14, 2010 | 04:06 PM
brian8you's Avatar
brian8you
89 eletrical issue
I bought an 89 bronco 5.8w and it turned over but definitly needed a new fuel pump. Everything eletric worked on the truck lights radio locks even the rear window. Today I put the new fuel pump in and a brand new bateri I tryed to start it up and got nothing no lights just a click and the tack went up to one and baterie showed 1/2 charged. I tryed starting it aggain and still nothing i tryed a window and nothing the only thing working as my locks and the A/C. I also tryed 2 other bateries thinking that could be it. Any ideas what it could be im going to go threw the fuses and put new leads on there tomaorw, could it be related to the fuel pump?
also im new here did i post this in the wrong spot?
thanks for the advice!!
Old Feb 14, 2010 | 04:44 PM
Kemicalburns's Avatar
Kemicalburns
sounds like a grounding issue. i would retrace your steps and go over everything.
Old Feb 15, 2010 | 11:15 AM
brian8you's Avatar
brian8you
It wast the grounds and it looks like i did everything right on the fuel pump? any new ideas. Would a shop be able to trouble shoot this for me using a fancy computer system?
Old Feb 15, 2010 | 08:02 PM
Kemicalburns
electrical work is spendy. did you drop the tank again and reconfirm everything.
Old Feb 15, 2010 | 08:49 PM
vtjvt's Avatar
vtjvt
sounds like a loose or faulty connection at the battery or solenoid, I would check all the cables and trace both from end to end
Old Feb 16, 2010 | 05:10 PM
brian8you's Avatar
brian8you
I dropped the tank again to check it all and it seemed fine. It is not the battery but the solenoid seems like a good possibility. if that don't do it is there a tool that can read my connections?
Old Feb 17, 2010 | 06:18 AM
Encho's Avatar
Encho
The Southernmost Mod
The tool: a piece or automotive wire. Just check the diagrams on the relays and try to connect them directly using the wire, it will serve you to test them.
