shoot,ive seen more dovetail rears than fronts.y jack the thing to the sky with a lift when u can get same clearance and keep center of gravity down to low as possible.imo dovetailed rigs look bada**!
did u figure out the headlight issue?u could just get some smaller lights and make a bracket to fit in stock location.i think the dovetail is a great idea.i dont know what terrain u wheel but it sure will help u keep that full size rig off the trees and rocks.
the rigs ive seen dovetailed sure gained clearance for larger tire uptravel.when tires are stuffed u dont have a fender directly above the tire.u if are worried about clearance turning y not just remove some of the inner fender wall if ur tires are rubbing?enlighten me on how dovetailing helps w/ turning?
Hey kris, check your yard... I think the truck load of fail you ordered just arrived.
