Dynatrac installation tips/tricks
Old Feb 13, 2010 | 09:20 PM
Waltdog's Avatar
Waltdog
of American machinists
Post Dynatrac installation tips/tricks
All my parts are here so I will be installing a dynatrac soon. Looking for any tips from folks that have done this. Any help or feedback is great!
This is my list of parts
Dynatrac free spin kit with Warn premiums.
New "X" code heavy service springs from Deaver suspension w/ new u-bolts
Powerslots (cryoed) and Hawk LTS's
Stainless brake line kit from SDHQ
New OEM ABS sensors courtesy of ED
New Goodyear Wrangler Duratracs (325/65 R18)E
Old Feb 13, 2010 | 09:34 PM
worm5932's Avatar
worm5932
unbolt, remove, reinstall, torque to specs!! good luck!!
Old Feb 13, 2010 | 09:46 PM
PaysonPSD's Avatar
PaysonPSD
Sorry Walt. I have no experience with the Dynatrac. Hell, I came to this thread hoping you were giving out tips/tricks.
Do a Write-UP with Pics.
You got allot of good stff. Christmas in February. Cool.
Edit : Found this Dynatrac Front Hub Conversion
Old Feb 13, 2010 | 10:23 PM
worm5932's Avatar
worm5932
that first post sounded rude...wasnt meant to be! i work on huge comercial hvac equitment and i disassemble stuff ive never seen before every day. dont be intimitated be confident. just fix it!!
Old Feb 13, 2010 | 11:06 PM
PaysonPSD's Avatar
PaysonPSD
Didn't sound rude to me. But it was very succinct.
Old Feb 13, 2010 | 11:12 PM
USAF CCM's Avatar
USAF CCM
I installed this kit minus the new front springs you have. Install was straight forward.....MY BEST TIP IS: read the instructions all the way through before starting, and refer to them often!
I followed Guzzle's front brake instructions and also installed the new pins in the caliper.
Having a bearing greaser helped a lot. You've spent some good money there.....do the research and find the best grease suited for you. I went with Schaeffers Moly 221.
Did you get new u-joints for the front axles? I really packed in the grease in the hubs before I installed the back dust seal; this really helps keep water out. I mean I REALLY PACKED the grease in the hub!
When installing the small snap ring on the outer tip of the short axle, be prepared to have to use a crow bar on the back side (between knuckle & u-joints) to pull axle outward, thus providing enough space to install that snap ring.
Be careful when removed the ABS sensor from each hub.....I accidentally snapped one.....another $130 later I was good-to-go.
If you don't have an axle nut socket with 4 to 6 prongs or tabs to match the nut you got with the kit, I say get one from an auto parts store that sells tools.
I also didn't worry about removing and reusing the four studs from each hub. Eight new studs weren't expensive at all, I got them and the new caliper pins at the same time.
It's been 1.5 years since my install, so I'm afraid that's all I can remember. Keep us informed as to your progress. I have photos, but haven't taken the time to download. Best of Success! I think you'll like the kit.....I love mine.
Old Feb 14, 2010 | 12:36 AM
Layson's Avatar
Layson
Pressing out the Ujoints in the stub shafts was the hardest part. otherwise it is a piece of cake..
Old Feb 14, 2010 | 09:49 AM
Waltdog's Avatar
Waltdog
Thanks for the link!
Tried to rep you but the police have me in time out
Old Feb 14, 2010 | 10:00 AM
Waltdog's Avatar
Waltdog
Thats a good idea, I am going to have the calipers off anyways, might as well get the new pins. What type of grease do I use on the pins?
Ill look into a bearing greaser, Ive got some Shaeffers 274, ill check the 221 out.
U joints are less then a year old form my ball joint got,hoping to re-use them.
See OP, 2 new sensors.
I bought the socket from a Matco tool truck.
Thanks for the info ,replies to questions above in blue.
Old Feb 14, 2010 | 10:47 AM
PaysonPSD's Avatar
PaysonPSD
My pleasure. Used Google and search string Dynatrac site:ford-trucks.com/forums Just replace Dynatrac with what you are searching for. Works better then the Forum search tool.
Reps unnecessary, but thanks for trying.
00X7.3PSD
Mar 4, 2026 10:38 PM
Waltdog
21
Mar 1, 2010 08:14 PM
thedaddycat
Jan 25, 2010 11:07 AM
Amboy Tom
Aug 26, 2009 09:13 PM
