body lift?
Old Feb 13, 2010 | 08:42 PM
shameless's Avatar
shameless
body lift?
Looking to find a Body lift for a 2001 explorer sport. Does anyone know where I can find one, or if one for a sport track will work? any help would be awesome!!!
Old Feb 13, 2010 | 08:46 PM
shameless's Avatar
shameless
Also, with a 3 inch body lift, how big of tires could I fit? anybody know?
Old Feb 14, 2010 | 12:06 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
you can get one for a ranger and it'll work fine.
you can prolly stuff 32-33s with just a BL. with a BL and torsion twist and shackles you would more easly fit 33s and possibly stuff 35s with trimming.
Old Feb 14, 2010 | 06:55 AM
ncranchero's Avatar
ncranchero
......then you'll need to change your front & rear gearing or it'll be a D O G !! Here's a tire size calculator for you to consider. The bottom row will show the % difference in diameter. Apply this to your gear ratio and see what happens to it........
A 33x12.50x16 is 15% larger than a 235/70R16. If you have 4.10 gears you end up with around a 3.50 and if you have the 3.73's you get a 3.11. Neither is real good for off roading. You'll kill a clutch or auto tranny like that and the auto won't shift right either. Oh, you'll need to own a gas station too. Just things to think about. Good luck!
http://www.1010tires.com/TireSizeCal...bmit&reset=yes
Here's a good article you might want to read on the body lift though.
http://www.mysporttrac.com/mysporttr..._lift_info.pdf
Old Feb 14, 2010 | 11:19 AM
shameless's Avatar
shameless
I'm not gonna be mudding it much if any, but I do get off the paved road fairly often running Vol. EMT. I though about lifting it a little and staying factory on the tires, but just to give it a little clearance. what do you guys think?
<a href="http://s687.photobucket.com/albums/vv239/glockstrap/?action=view&current=explorerlift.jpg" target="_blank"><img src="http://i687.photobucket.com/albums/vv239/glockstrap/explorerlift.jpg" border="0" alt="Photobucket"></a>
Old Feb 14, 2010 | 11:37 AM
ncranchero's Avatar
ncranchero
Makes sense to me. Is it a 4x4? Crank up the torsion bars on front, getting the new keys if need be. Air shocks on the rear or relocate the axle to under the springs. Running EMT I'm sure no one needs to go into what a higher center of gravity will get you..... Mine is a 4x4 and I dropped it 2" !
Old Feb 14, 2010 | 11:41 AM
shameless's Avatar
shameless
lol no, I understand full well the consequences of high center of gravity. lol we do live in farm country here in S.E. ohio and I've ended up in more than one field or tractor path with the ol'girl. so does it look ok, or does it look stupid without going with bigger tires?
Old Feb 14, 2010 | 11:56 AM
ncranchero's Avatar
ncranchero
I think it looks ok. The 265/75R16's would fill up the wheel wells and give a hair more axle clearance without messing up the gearing, etc. IMO the body lift would be a big waste of effort and $$.........just my 2 cents.
Mine, stock height. Cranking the torsion bars would have evened out the "high" look.
But I do little off-roading, using the 4wd for slippery surfaces, and prefer stability and handling. Here it is now after the 2" drop.
AmbnGnt
Escape & Escape Hybrid
16
Jan 18, 2016 02:47 PM
Brew6654
New Member Introductions
Feb 4, 2008 12:11 AM
Shawn_Whiteley
Oct 4, 2005 06:19 PM
fords_built_tough
May 20, 2002 06:31 AM
lowcountry
Offroad & 4x4
Nov 6, 2000 06:46 AM
