Redline information.
Old Jan 19, 2003 | 01:29 PM
erikl85's Avatar
erikl85
Does anyone know what the redline on a 1977 ford f-250 with a 460 and a c-6 is? And is there anyway to increase it?
Thanks.
Old Jan 19, 2003 | 02:46 PM
Torque1st's Avatar
Torque1st
Posting Legend
Redline on a given engine is based mostly on the camshaft and mechanical limits. The most important redline is based on the mechanical limits of the engine structure and valve train. You do not want the rods to fly out or the valves to float. The camshaft grind determines the second redline which is based on the breathing and efficiency characteristics of that cam. In other words beyond a certain point you are getting diminishing returns in torque and HP. Redline is usually set at just beyond the HP peak of the engine where the HP starts to drop off rapidly.
To increase the redline in an engine they are balanced and blueprinted with a better valve train, breathing, and camshaft. When you do this you may also loose low end power and torque which can cause drivability problems in a daily driver.
For more information check out the Performance engine building section and the 460 engine forum.
Old Jan 19, 2003 | 03:27 PM
erikl85's Avatar
erikl85
Thanks, is there a way to calculate redline?
Old Jan 20, 2003 | 02:04 AM
Torque1st's Avatar
Torque1st
Posting Legend
Is the engine stock?
If it is, -probably 4500 rpm
They will turn a little faster but it won't do any good.
You can enter your engine specs in a dyno program to see the HP and torque curves or you can check the max HP @ rpm for the engine listed in many repair manuals and add 500-1000 rpm.
eco
Jan 28, 2006 10:03 AM
SuperBlue
Modular V10 (6.8l)
Sep 1, 2005 10:33 AM
f15terwitha6ter
21
Mar 8, 2005 10:10 PM
strseantrent
Nov 26, 2002 08:24 PM
Outpost22
Sep 10, 2002 02:19 PM
