evolution or ts
Old Feb 14, 2010 | 07:11 PM
jdamato1's Avatar
jdamato1
Ok you guys win. I'll buy the ts chip from advance or xdp for 235 and send it to wildman for a tweak. Now how do I fix the speedo problem ?
Old Feb 14, 2010 | 07:22 PM
F350-6's Avatar
F350-6
Hang around here. Odds are you'll find someone or some event close enough that you can meet up with someone who has an AE that sill adjust the speedo for you.
When you send the chip to Tony, be sure to note the lift, tire size & rear end gears on his website order forum.
Old Feb 14, 2010 | 07:49 PM
jdecker88's Avatar
jdecker88
You stated you had a 4 position chip I know you can send it to Beans and have them tune it for a hundred bucks they can do old style chips just call them up and save you some money from buying a new TS chip.
Old Feb 14, 2010 | 08:11 PM
worm5932's Avatar
worm5932
you can buy a chip directly from wildman, id go that route. in case of any issues for the first year, theyre right on his homepage.
Old Feb 14, 2010 | 09:47 PM
jdamato1's Avatar
jdamato1
The chip from wildman is 300 plus each slot filled. Chip from advance or anywhere else is only 235 with all 6 slots filled. It's cheaper to buy it anywhere else and have him tune it.
Old Feb 15, 2010 | 04:15 PM
jdamato1's Avatar
jdamato1
So where do I go to get my speedo adjusted eight and what does the wicked/borg warner wheel do. Im looking to get a lil whistle out of the turbo. Any reccomendations ?
Old Feb 15, 2010 | 04:59 PM
farmb0y's Avatar
farmb0y
A wicked wheel is the same wheel that comes on OBS and early '99 trucks. It is a little less efficient at moving air and in turn reduces the amount of surge when under heavy loads. It will give you more whistle. Another way to obtain that is by removing the foam on the IC pipes. But the best way is to get a 38R!!
Old Feb 15, 2010 | 05:03 PM
jdamato1's Avatar
jdamato1
Where is the foam I need to remove ?
Old Feb 15, 2010 | 05:06 PM
farmb0y's Avatar
farmb0y
Maybe your's doen't have it, but the intercooler (IC) pipes go from the turbo to the IC and back. Looks like tin foil wrapped around them.
I didn't have to do it, my pipes didn't have it, but the newer trucks do.
Old Feb 15, 2010 | 05:15 PM
jdamato1's Avatar
jdamato1
I have foil around the ic pipes. Where is the foam though ?
Old Feb 15, 2010 | 05:20 PM
farmb0y's Avatar
farmb0y
Foil, foam, same thing.... I mis-spoke, sorry for the confusion.
Old Feb 15, 2010 | 05:21 PM
jdamato1's Avatar
jdamato1
So removing the foil makes the whistling sound more pronounced ?
Old Feb 15, 2010 | 05:48 PM
  #28
worm5932's Avatar
worm5932
yeah foil delete. ive read about it but havent got to it. remove the intercooler pipes and inspect the boots(rubber couplings) if they are in poor shape, get new ones, cut the foil and remove the insulation, the glue will require heavy duty adheasive remover. ive read it is not to bad to do and will increase the whistle, if it wasnt so cold and white out id know!! there will be oil residue in the pipes, i suggest the 6637 filter and ccv delete to stop that, also easy. i just did the wheel, 6637, and ccv, much more whistle. im tryin to come up with a solid pipe between the turbo and filter, that might help as well. there are some threads with pics and links i would put up, not to good with computers.
Old Feb 15, 2010 | 05:55 PM
  #29
jdamato1's Avatar
jdamato1
What Is the ccv delete And the 6637 delete ? You guys are killing me. I have all week off so feel free to fill up my schedule. Live in PA so anyone in the area want to give me advice on where to shop let me know.
Old Feb 15, 2010 | 06:15 PM
  #30
jdamato1's Avatar
jdamato1
So Do i need the boost regulator to ensure the fuel doesn't trip out with the new chip.
