block id question
Old Feb 13, 2010 | 11:45 AM
Not Steve's Avatar
Not Steve
block id question
I've been searching around on here looking for id # and not finding what I'm looking for. I'm nearly computer illiterate so this does'nt surprise me. The number on my 240 block is O6AE-6015-D as far as I can tell they're rather worn, my question is,is this a 240 or 300 or can I tell by the numbers? If some one could direct me to a site about this info I would appreciate it! Thanks!
Old Feb 13, 2010 | 12:24 PM
garbz2's Avatar
garbz2
Measure the stroke.
240 is 4.00 x 3.28
300 is 4.00 x 3.98
you can do this with a women dowel or white solid copper wire.
Remove the number one spark plug, disconnect the coil. put the rod in the hole and use a socket to spin the engine do one complete revolution marking the bottom of travel and top of travel. this will give you the stroke of the engine.
240s and 300 are identical on the outside.
Garbz
Old Feb 13, 2010 | 12:26 PM
IsoGrifo's Avatar
IsoGrifo
pretty much the only way to tell for sure is to take off the head and measure the stroke, 240 is just over 3 inches, 300 is just under 4.
a little think I learned though, look at your oil pan, where is the drain plug?
300 will have it in the center, 240 on the driver's side. not necessarily a for sure way to tell, but you can be fairly certain. also, since the 240 and 300 are pretty much the same engine, almost all gaskets and parts are the same, a few that are not... dipstick, I believe the timing cover has different timing marks... and that's about it haha.
Old Feb 13, 2010 | 12:28 PM
Bill W's Avatar
Bill W
1965 F100/350 240 I-6 specs: B&S: 4.00" x 3.18" / 150 Gross HP @ 4,000 RPM / Torque: 234 ft. lbs. @ 2200 RPM.
1965 F100/350 300 I-6 specs: B&S: 4.00" x 3.98" / 170 Gross HP @ 4,000 RPM / Torque: 283 ft. lbs. @ 1400-2400 RPM.
above is straight from a ND post, easy way is to pull a plug and measure the stroke
3.18" = 240
3.98" = 300
Old Feb 13, 2010 | 12:29 PM
IsoGrifo's Avatar
IsoGrifo
Garbz, only way I knew about the oil pan is from Bill's 65 240 he gave me that I can compare with my 300, built 8 days apart!
(Cool thing, mine and his 65's were built in the same plant at the same time!)
Old Feb 13, 2010 | 05:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Not Steve
The number on my 240 block is O6AE 6015-D as far as I can tell they're rather worn, my question is,is this a 240 or 300?
There's no such casting number prefix as O6AE, it's C6AE
All 1965/74 240/300 engine blocks were cast as 240's, measuring the stroke is the only way to know which one it is.
240's were used in 1965/74 F Series Trucks & Econolines / 1965/72 Galaxie/LTD's.
My guess is...with this C6AE casting number prefix, this is a 240 I-6 originally installed in a 1966/67 Galaxie/LTD.
Originally Posted by Iso Grifo
...take the head off and measure the stroke.
(sigh) It is not necessary to remove the cylinder head to measure the stroke.
Old Feb 13, 2010 | 05:26 PM
Not Steve's Avatar
Not Steve
Excellent information! I wasn't sure if you could tell by the block #, now I know for sure. I'll measure the stroke tomarrow in the daylight, if the wife lets me it is Valentines Day and all. Thanks for the info guys!
Old Feb 13, 2010 | 06:08 PM
Not Steve's Avatar
Not Steve
Well, I just measured the stroke and it is a 240, and the oil drain plug is on the drivers side. So at least now I know what I'm working with. Once again thanks for the info!
Old Feb 13, 2010 | 10:27 PM
IsoGrifo's Avatar
IsoGrifo
BAM!!! It has been confirmed! And I know you don't have to take the head off, but it was fresh in my mind cuz I just had mine off.
trozei
40
Sep 12, 2020 09:22 PM
Doubleclutch
May 17, 2016 08:06 AM
Bruce1534
Dec 10, 2015 05:58 AM
Pops Chop Shop
Apr 21, 2012 01:26 PM
Eston Newbern
Sep 27, 2010 01:21 PM
