brake controller voltage issues...
Old Mar 5, 2010 | 05:05 PM
CPUNeck's Avatar
CPUNeck
Originally Posted by derekmj64
the test results were the same as before 2.4 volts without hitting the brake and when hitting the brake I was only getting approximately 6.3 volts (all with the truck running.)
Look behind the driver rear wheel area close to the spare tire ~ 12" from the bumper... You should have a fairly thick harness and a nice big harness junction. IIRC it should be some what square. You can kinda follow the harness from that area and confirm that it is going to the trailer tow receptacles. Disconnect the harness there, then recheck your voltages at the brake controller harness (under the dash.) See if any of your findings change.
Old Mar 5, 2010 | 05:26 PM
WideOpenFord's Avatar
WideOpenFord
i mean what were the results to the test i told you in post #9, doing those test first would of proved the bpp was not bad in the first place...
Old Mar 5, 2010 | 05:31 PM
WideOpenFord
oh yea any check the voltage for the trailer brake lights while hitting the brakes, in your case it should be 6 but its supposed to be 12, it will get us one step closer though
Old Mar 6, 2010 | 01:37 PM
derekmj64's Avatar
derekmj64
I did that a couple of weeks ago and the problem was still there. If I can not figure out what the problem is I am probably going to do what RV-Tech suggested and cap the wire off and run a new one from the bpp.
Old Mar 7, 2010 | 08:05 AM
derekmj64's Avatar
derekmj64
So i just noticed last night that my third brake light on the cab of my truck is very dimly lit when the brake is not hit then lights up fully when hit. I believe that this is another result of my issue. I am back feeding somewhere I just need to tear into it deeper.
Old Mar 7, 2010 | 08:15 AM
RV_Tech's Avatar
RV_Tech
Man, when you start getting crazy things happening, you are usually looking for a grounding problem somewhere. On RVs, I start by redoing the battery/chassis grounds, but sometimes I am amazed where I end up. Electronics go nuts with bad grounds.
Good hunting,
Steve
Old Mar 7, 2010 | 08:16 AM
CPUNeck's Avatar
CPUNeck
Try your hazard flashers. Maybe while they are on, retest your brake controller voltages. Sounds more and more like the multi-function switch.
Old Mar 7, 2010 | 07:14 PM
derekmj64's Avatar
derekmj64
I will start to go through tomorrow and clean some of the grounds as well as check the voltage with the hazards on. Thanks for all your guys help. I hate troubleshooting DC!
Lt340
Sep 21, 2015 09:09 PM
91Fbody
35
Apr 30, 2015 03:41 PM
robear54
All Things Towing
Jul 28, 2012 09:39 AM
darinbrooks
Dec 1, 2010 06:23 AM
derekmj64
All Things Towing
Feb 13, 2010 10:58 AM
