Excursion v-10 won't start
Old Feb 12, 2010 | 02:17 PM
montgomery7's Avatar
montgomery7
Ok, last night this thing was acting like it was running out of fuel ( cut off 4 times before making it home) total of about 4 miles. Replaced fuel filter,idle control valve about 6months ago. Checked the fuel pressure on gauge with switch on and there was nothing. This morning it would start up and run for about 3 seconds and die. cleaned the idle control valve put it back on and now i have nothing it want even start up. If anybody could help it would be wonderful. thanks in advance
Old Feb 12, 2010 | 02:27 PM
Immortal_Ben's Avatar
Immortal_Ben
did you just happen to fill up with gas? mayhap you got some bad gas.
another guess would be a vacuum leak under the hood. were you working under there before the troubles started?
and welcome to the forum
Old Feb 12, 2010 | 02:38 PM
montgomery7
It was sitting on a heel for about 6 hours and i did put 20.00 in it but the fuel pressure gauge has no reading i checked my gauge on my mustang and had about 25 pounds the excursion had 0. I do have 245000 on this v-10
Old Feb 12, 2010 | 02:46 PM
tdappleman's Avatar
tdappleman
How are you checking the fuel pressure? At the rail? Can you hear the fuel pump run at all with the key on? Does anything else work with the key on?
I'd start with checking the fuel pump fuse and the fuel pump interrupt switch in the passenger kick panel.
Old Feb 12, 2010 | 03:29 PM
montgomery7
Yes, checking pressure at rail. i have no pressure there everything else works, lights radio etc. motor turns over but it will not start. last night it acted like it was running out of fuel, this morning it would start and run for 3 or 4 seconds and die. now it will not even start. where is the fuse for the fuel pump and this other switch your talking about, i was going to test power to pump tomarrow it it's not snowing. thanks for your help.
Old Feb 12, 2010 | 03:36 PM
Bigjakes12's Avatar
Bigjakes12
Had a similar issue some months back. Theres a 30 amp fuse that handles the ignition etc. Wish I could remember the number ( & don't have my book or truck close) Pulled it out & sprayed contact cleaner in behind it. Let it set for a few hours & runs like new. Must have had some gunk back there. Let us know what you find.
tdappleman's Avatar
tdappleman
The fuel pump fuse is #40 in the fuse panel under the steering wheel. The interrupt switch is in the passenger side foot well in the kick panel. Check your manual for a picture which may help you find it - once you do then just push the button down to ensure it's closed.
Old Feb 12, 2010 | 03:44 PM
montgomery7
Thanks, i'll check this out as soon as possible, 5 kids and the mustang don't go in snow. haha.
Old Feb 12, 2010 | 04:42 PM
shadows4's Avatar
shadows4
Sounds like a bad fuel pump to me. Check fuses first then for power at the pump. Listen for the pump when you first turn on the key. If it is the pump hope there isn't much fuel in there. Good luck, John
Old Feb 13, 2010 | 09:10 AM
Hollywood703's Avatar
Hollywood703
I agree with the fuel pump, or beyond that....its not the ignition as its turning over, its not the electrical as you have power to the lights radio and ignition.....what about plugged fuel filter? it is curious that gauge is showing no fuel though.....im not familiar with fuel delivery system, if the fuel tank fill sensor goes bad will it default the pump to off?
Old Feb 13, 2010 | 09:16 AM
Airslot's Avatar
Airslot
Is the fuel level sending unit built into the pump on these as it is a Chevy? I vote fuel pump assembly.
Old Feb 13, 2010 | 11:01 AM
montgomery7
alright, checked the pump cut off switch,and the fuel pump fuse both were fine. put my key in and it started up and then died started it again and it ran for about 4min. This is driving me alittle crazy now. first i had no pressure on gauge and it wouldn't fire now it's starting again. making me think maybe filter i don't know.
Old Feb 13, 2010 | 11:51 AM
montgomery7
Also does anyone know what the upgrade tire size is for this think that wont strub.
Old Feb 13, 2010 | 03:05 PM
montgomery7
changed fuel filter, started up fuel pressure at rail said 35 pounds. drove it about 2miles seemed fine except for when you give it gas and let off of it it drops down and just about cuts off and then it picks up and idles fine, if you have any input on this let me know, thanks in advance. (the fuel filter was pretty dirty it poured black grit out for a while.)
Old Feb 14, 2010 | 11:26 AM
rlh68050's Avatar
rlh68050
Fuel pump!! or a bad connection at the pump. Either way you have to drop the tank to get access. If I had the tank down, there is no way I would put it back up without installing a new pump assembly regardless of what you find. Go to to the Ford dealer to get on too. I wouldn't waste my time with aftermarket.
