question about a 74 351m
Old Feb 13, 2010 | 01:08 PM
Krazy351w's Avatar
Krazy351w
Got the engine tore down to short block today. It was a PITA!! takin it tomorrow to have it machined and preped, Im thinking im gonna go with a .060 overbore.
Old Feb 13, 2010 | 01:43 PM
zaaac's Avatar
zaaac
I'm wondering why you want to go to .060 overbore instead of .030. The extra 5 cid from the extra .030 overbore isn't going to be noticed and all you'll end up with is thiner cylinder walls. This is jmo, of course. Everyone has different ideas. What do others think?
Old Feb 13, 2010 | 01:44 PM
go_racing84's Avatar
go_racing84
Yeah, I would just go as far as you have to in order to clean it up. I don't know that I'd go .060 on a 400 anyway...
Old Feb 13, 2010 | 02:01 PM
Krazy351w's Avatar
Krazy351w
my brother built up a 351m a few years back and went with a .060 overbore and it didnt have a single problem. Guy that machining it says it will be perfectly safe aswell. I say why not? If a .060 is equivalant to 10 ci's that would put me at a 412. And in terms of saying if i ever have to go back into the motor, i look at it like this. 351m/400 blocks are a dime a dozen.
hollenjoe's Avatar
hollenjoe
Yeah they dont like anything beyond 0.040
Old Feb 13, 2010 | 02:09 PM
Krazy351w's Avatar
Krazy351w
well the guy im having do it has been building race engines for the local dragsters for year and he said he sees no problems with a .060 overbore.
Old Feb 13, 2010 | 02:40 PM
hollenjoe's Avatar
hollenjoe
so has he done any 400s? these are not usually race engines so he probably has no idea on a 400
You may get away with it , but you still have to check your cylinder walls..
Also the extra CID wont help much your power but could create a chronical overheater...
Anyways its still your choice...
Old Feb 13, 2010 | 02:46 PM
Krazy351w's Avatar
Krazy351w
He has a 74 gran torino elite with a 400 so im sure he knows his way around it.
CID's make power, im not saying it will be a night and day differance.
With a good 4 core rad dual efans and the right termostat temps wont be a problem at all. like i said my brother has a 351 that was bored .060 over and its running the factory rad and tstat with no heating problems, so im not gonna worry much.
Old Feb 13, 2010 | 06:50 PM
zaaac's Avatar
zaaac
I'm sure there's a good chance you won't have a problem. I think I read somewhere if you want go more than .030 the cylinders should be sonic checked before hand. I was just curious your reasoning and like you said there are plenty of these engines out there.
Old Feb 14, 2010 | 09:47 AM
mustang81's Avatar
mustang81
Why your brother over bore to .060 to make extra 10 cid. I defenitely change crank and piston of the 400 to .030 over to make at least 50 cid more. Why do you want to go to .060 ?
Old Feb 14, 2010 | 06:39 PM
hollenjoe's Avatar
hollenjoe
You could always leave it to luck....
The 351M/400 engines have "thin wall" castings and can not be safely over-bored beyond .040" -- Okay. Don't let this scare you away from "M" block engines. Ford did this to save weight. An "M" block engine is good for one or two complete rebuilds before you have to sleeve the block. All this means is that you can't over bore an "M" engine much beyond .040". As an example, when I had my engine rebuilt, the shop found that the #1 piston's wrist pin came loose and scored the block. A .030" over bore would not clean this cylinder up, so they had to put a sleeve in it. Big deal. It cost me $75.00 to fix it.
source:
Rumors & Myths
Old Feb 15, 2010 | 02:34 AM
Jetman's Avatar
Jetman
You would come out better stroking the motor and gettingj some more power from having you heads worked. .60 overbore is definitely pushing it to the outer limits. Check out some of the stroker kits out there.
clydes 74 ford
Jan 30, 2015 03:11 AM
bigfoot7180
Jul 22, 2011 12:56 AM
74 F100 351m
Jan 14, 2006 01:30 PM
74 Blue Pile
Engine Swaps
Jun 1, 2004 01:28 AM
74 F100 351m
Nov 18, 2003 09:01 PM
