Sponsored by: Auxito
How to Troubleshoot and Fix F150 4X4 1997-2003
Old Feb 24, 2016 | 06:26 PM
  #121
slogano's Avatar
slogano
same problem
Originally Posted by eagleclaw
Hey Ricky. Thanks for the additional info. I will definitely check for hairline cracks in the vacuum lines. I am also going to check the Transmission Range Sensor Switch part # 4L3Z 7E440 AB located on the left front of the transfer case. I saw that JackPiner57 had a similar problem but the opposite of mine. His truck stayed in 4x4 drive when hot and would shift back to 2x after the truck sat and cooled down.
I normally work on my own truck but this time I was told by several people that I need to find a mechanic who could rebuild the transfer case. The mechanic I used came highly recommended. I would tackle just about any job but this called for a lift that I did not have.
He looked at the transfer case and shift linkage and informed me that he did not feel that the transfer case was the problem. He stated that the linkage was sloppy and was not engaging the shift fork all the way. I did have some binding problems with the linkage from time to time. I hit it several times in the past with white lithium grease. While he was working on the linkage, I had him change the automatic tranny fluid, filter and gasket. I also had him replace the rear transfer case yoke seal. (starting to leak slightly). After he changed the linkage, he took it for a ride and everything seemed to work smoothly. I asked him to drive the truck for while and then he noticed that the truck would not shift back into 4x4 when hot. That's when he swapped out the 2 vacuum switches on the firewall. I don't know if he checked for vacuum leaks on the lines. I will ask him and then check them myself. I am really hoping that it is the Transmission Range Sensor Switch part # 4L3Z 7E440 AB . After this, I am going to tackle the Blend Door. (This door stopped working several years ago. I just got the improved door from Dorman). Thanks again for your help. I will keep you posted on my findings.
RC
I have been having the same problem. My 4x4 wont shift into gear unless i am at a cold start. I replaced the transfer case motor because we thought that the old one was dead. however once i am in 4 wheel, there is no slipping. it seems to be a heat type of issue. cause all the times i've had to engage my 4 wheel its worked off of a cold start but not when running for a while. one time i was stuck in a very small mud puddle but i couldn't get my 4 wheel to engage, i turned my truck off for a while. i called my friend but had decided to try my 4 wheel again. after being off for half an hour it went right into 4x4. Please help
Old Dec 5, 2016 | 02:44 PM
  #122
Eddiewayne6's Avatar
Eddiewayne6
4x4 wont work in 97 f150
thanks to your information we found our issue and now we can fix it..thank you so much..tracy
Old Dec 5, 2016 | 07:56 PM
  #123
brokenleg's Avatar
brokenleg
some of these people must be really uninformed. a 1997 F250 HD isnt the same truck.........
Old Dec 8, 2016 | 09:25 AM
  #124
Michael Campbellx's Avatar
Michael Campbellx
Originally Posted by DIYer...
First off... THANK YOU for this post. I followed your advice on replacing the solenoids because they weren't clicking. After replacing both, they still didn't click. I have power to both of them and the SOTF switch also has power but nothing happens when i turn the switch. Is it possible that the 4x4 switch is broken? Otherwise, maybe there is a wiring problem from the switch to the GEM or from the GEM to the solenoids?
Any one else have problems with this?
(Nothing at all happens when i turn the switch, no light, no click in the solenoids, no change in vacuum)
Thank you
DID You ever fix it? If so, what did u find ?
Old Dec 31, 2016 | 04:40 PM
  #125
ooseven's Avatar
ooseven
So i encountered a problem with a truck i had just bought, reverse works as it should when i go into drive it bogs than dies when i go into 1 or 2 it makes a grinding sound then dies. any idea of what it could be? 4x4 on or not it does the same thing. also i have a 98 ford f150 would the transmission and the transfer case swap over. also when going down road let up off gas it seems like it shifts up and down.
__________________
Thank You....
P.S.
Plus I'm posting to keep this active :-)
ooseven
2000 F150
Info
Old Jan 31, 2017 | 10:30 AM
  #126
trukn07's Avatar
trukn07
4x4 troubleshooting
I have an 03 f150. I have no power at 4x4 switch. Several people in this thread have the same problem. Unless i overlooked it i have yet to see a solution or suggested solution for this. Where is the GEM and relay located and is there a known issue with these and or a diagnosis for them? The 4x4 did work for a while then started intermittently working then just quit altogether. I have as i said no power at the switch, no light, nothing. All other components test good. Thanks for any help.
Old May 28, 2017 | 02:40 AM
  #127
Ewlsu's Avatar
Ewlsu
Hey guys I'm new here !!! I have a 2000 ford f150 4×4 and I need help!!! When it's raining or I wash it it runs horrible, also when dry and I put it in gear it dies if I don't give it a bit of gas ! And as well it spits out a manufacturer code any suggestions
Old May 28, 2017 | 07:40 PM
  #128
Sam I Am's Avatar
Sam I Am
This has nothing to do with the 4X4 system, you should post a separate thread explaining your issues and list the codes.
Old Jun 28, 2017 | 05:12 PM
  #129
Melissa Bell's Avatar
Melissa Bell
What was the fix
I have the same exact problems you were having. I read through the post and could not find where you stated what fixed the problem. Would you be kind enough to tell me what fixed your problem. Thanks
Old Jul 16, 2017 | 07:57 AM
  #130
thr57's Avatar
thr57
troubleshoot 4X4 dash switch
My 1997 F150 4X4 has the dash switch to engage front wheels. In no position does the lights come on and front wheels are not engaging. Can anyone help me with plan to troubleshoot this?
Old Sep 20, 2017 | 11:07 AM
  #131
MN_Jack76's Avatar
MN_Jack76
4X4 Light
Greetings,
I have a 2000 F150 V-8 5-Speed with a manual transfer case shifter. My 4X4 dash light will not shut off. I believe I damaged something with my own stupidity. I was replacing the dashboard bulbs to LED's. Because the LED's I bought are polarity sensitive I had power onto the dashboard circuit board so I could see if the LED lit. The 4X4 bulb took a lot of tries as it was not making a good contact. I believe in pulling out and re inserting the led several times I hurt something. The truck does go into and out of 4X4 but the light stays on. I unplugged what I believe is the 4X4 switch (on the front left of the transfer case near the linkage) on the transfer case and the light stays lit. Any ideas what electronics I may have damaged and where they are located?
Thank You in advance!
Jack
Old Mar 23, 2018 | 09:40 AM
  #132
Rob_Schu's Avatar
Rob_Schu
tranfer case stays in 4hi
Originally Posted by Peckerpage
I have a 1997 ford f150 my 4x4 is not working. 4x4 light dose not come on when I turn the switch to 4hi or 4 low . I have removed the actuator in the transfer case and put it in 2hi by hand but as soon as I turn the key on the transfer case goes back in 4hi again. l have changed gem, switch, vac actuator on firewall transfer case actuator and still nothing. Front diff is not engaged but it does work I have engaged it manually. I really need some help I'm starting to lose my mind thanks
I also have a 1997 ford f150 ESOF and have the same problem. Anybody out there have a solution. I think it must be a short to ground on a wire or maybe a bad relay somewhere. I haven't changed the GEM but don't have any other electrical problems and I read somewhere that that would be an indicator that the GEM is bad. 4wd selector switch tests good. Firewall relays test good. I to pulled the transfer case motor and switched it to 2Hi installed it and it goes back to 4HI dash light indicator does not come on.
Old Mar 31, 2018 | 10:06 PM
  #133
Rob_Schu's Avatar
Rob_Schu
Problem solved
I replaced the interior fuse box and the gem module with used ones I picked up from a salvage yard. 4wd is working again. There were some very small signs of corrosion on both units.
Old Apr 10, 2018 | 06:07 PM
  #134
Mark32's Avatar
Mark32
Originally Posted by Rob_Schu
Problem solved
I am having the exact same issue here.
Did you have any trouble matching up a new GEM module? Does it need to be programmed or anything?
Old Apr 10, 2018 | 07:57 PM
  #135
Rob_Schu's Avatar
Rob_Schu
I called or visited most all the area salvage yards before I found one, but I also saw a couple on Ebay. If the numbers match what is in your truck programming would not be needed. I know water had leaked in around the windshield at some point, probable cause of the problem with gem and fuse box. I believe I have that stopped now.
