1978 - 1996 Big Bronco
Engine swap ideas
Old Feb 11, 2010 | 12:54 PM
Kemicalburns's Avatar
Kemicalburns
gfw i am not sure that is correct. the 300-6 was a very rare option in the 78-9 broncos.
Now in 80+ the 300-6 equipped broncos tended to have a 3.08 gears since they where backed by a manual 4 speed or C6. 4.10's tend to be a special request and are rare in broncos in general.
the 300-6 got the higher ratio also because of cruising rpms. that motor doesnt like running at 2500rpms + for very long. and since it produces good amount of torque off idle the 3.08 worked.
Old Feb 11, 2010 | 02:36 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
That's why I should stay off the big Bronco forum. Just not familiar enough with them vs same year pickups. I thought a lot of the 73-79 era F-150's with the 300 and 4 speed had the 4:10 gears. Back to the EB's where I belong. I may be looking for the wrong thing too. I've hunting for a 79 stepside w/ 4-speed and 4:10's. Thanks for straightning me out.
Old Feb 11, 2010 | 04:04 PM
Kemicalburns
that motor was for sure in the trucks. i know because i had a 73 with 300-6 and 4speed with 4.10s. i loved the combo for sure.
a 79 stepside i think would be rare for sure. that combo wouldnt but you more then likely would find a 351m under the hood.
Old Feb 15, 2010 | 12:45 AM
Bronco Mann's Avatar
Bronco Mann
Put a fin on the back of the bronco and no exhaust will come in I have one on my 79 and exhaust runs out the back . If you weld the front up you will have trouble turning .
Old Feb 15, 2010 | 09:18 AM
FarmerFrank's Avatar
FarmerFrank
I know even when my exhuast was behind the rear tire i still got a ton of fumes with the window down. i know its illegal in PA but i still put it infront of the tire, louder and no fumes. also my 90 bronco has 3.08 and a 300 which i hate but will probably like when i get my 351w in with the 4 speed. a Lincoln 7018 locker (welded spiders) up front shouldnt hurt as long as you keep the hubs locked out going down the road but i wouldn't do the rear, one tire has to turn faster around turns.
Old Feb 15, 2010 | 11:18 AM
American Thunder's Avatar
American Thunder
Originally Posted by Kermet
Odd you guys should say that about the exhaust. if you plan on runnin round with the back window open...side output or rear output will have just the same gassing effect. Fortunatly the tops come off for complete and tottal enjoyment, And fresh air....
My exhaust exits just behind the passenger door, and angles down some like this:
If I drive with the rear window down, I get no exhaust inside. I could easily tell if it was getting inside, because the black smoke pours out when I get on the throttle hard. Another thing I noticed is that there's no black soot residue on the rear tire/wheel, so the exhaust must not be hitting there either.
Old Feb 15, 2010 | 11:39 AM
brian8you's Avatar
brian8you
American Thunder where did you get that exhaust paint or is it powder coated it looks nice
Old Feb 15, 2010 | 07:58 PM
American Thunder
Thanks, it's just satin engine enamel, since the diesel exhaust doesn't get all that hot, it holds up well.
Old Feb 15, 2010 | 07:59 PM
Kemicalburns
American thunder i assume you dont wheel that bronco much as the location for that exhaust would get damaged often being in the front of the rear tire
Old Feb 16, 2010 | 07:31 AM
American Thunder
The exhaust is protected pretty well.
Old Feb 22, 2010 | 10:05 PM
'96 Bronco's Avatar
'96 Bronco
well guys if he dont roll the back window down he wont get any fumes. I know my Bronco is notorious for burnin up those rear motors. So I havent had it down for goin on 5 years. I have had my exhaust ran straight out the back for like 7 years now. I dont know though. I may throw some 45s on there and throw it out to the side by the ends of the bumper.
Old Feb 23, 2010 | 12:04 AM
Kermet's Avatar
Kermet
MMMMmmmm yesssss.. Found me a set of 4.10's today. BUT this tired old goat of a motor has now turned into a smoker on the right side...Picked up crate 351m with after market timing gears for 300$ cdn.Busted the rear glass the oter day too. Any ideas on what to replace with?? i dont like havin to worry bout that explodeing "saftey" glass. ......now question. Recurving distributer...who know about and worked with.. should i bother??
Old Feb 23, 2010 | 12:08 AM
  #28
Kermet's Avatar
Kermet
Whoa, wrong thread...DOH!!
Old Feb 23, 2010 | 12:11 AM
  #29
Kermet's Avatar
Kermet
Found my 4.10's and havent notice any gassing yet, Window or no window...Broke it the other day...
Old Feb 23, 2010 | 09:22 AM
  #30
AbandonedBronco's Avatar
AbandonedBronco
off topic, how do i put a pic to my name?
Click on "User CP" in the upper left (along the blue bar.) Then, click on "Edit Avatar" over on the left side of the screen.
With the exhaust properly routed, it won't come in the back window (even though my users manual says to never drive with it down.) However, straight out the back can be deadly, even with the window up.
