Testing an EEC
Old Feb 9, 2010 | 08:33 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Testing an EEC
Let's say you found an EEC-IV that works for your application at a wrecking yard for a good price. How/where could you take it to get it tested to be sure it was working properly? Ford dealer? NAPA?
Please bear with this old carb guy as he muddles his way through EFI 201.
Old Feb 10, 2010 | 10:21 AM
xlt4wd90's Avatar
xlt4wd90
To do the most thorough test, you probably need to take it to the dealer. They use something called the "Rotunda" Tester that check out its entire function.
However, there is a simpler way to determine if it has basic functionality. Since you pulled the EEC computer, did you also pull the wiring harness and all its sensors and actuators? If so, you can hook them all up on a bench and run the KOEO test. If it runs the test, you can be fairly certain that it's working.
HD
13
Jan 9, 2016 07:05 AM
Building_Fords
Nov 3, 2015 05:45 AM
chase61
17
Nov 19, 2011 06:54 PM
hreed
1983 - 2012 Ranger & B-Series
Dec 4, 2003 10:18 PM
1owner88B2
Bronco II
Mar 31, 2002 03:52 AM
