1990 F250 Dana 60, Drum brake removal?
Looks like you're working on the drivers side (L). If you've released the e-brake try backing off on the e-brake adjuster on the cable.
The self adjuster on the drivers side has to be moved up ^ to loosen it. I just finished putting the passenger side back together and removing the drum on the drivers side. Neither would come off until I backed off the self adjuster.
If all else fails you could try removing the axle and hub to see if it will release. If you do be prepared to replace the seal @ $40 each and buy a specific spanner wrench @ $30 to R&R the hub nut. I'll bet it's the brakes though.
If you need a picture of the tool to release the auto adjuster let me know. It would be easy to get pictures of it and the star adjuster now that I have the drum off.
It is usually rust between the hub and the drum, if it was your brakes it will move a little then pull back in place.You will need to back off the star wheel to remove it. But if it won't budge and feels solid it is rust and the tight fitting between the hub and drum, the brakes can't hold it solid.
Rusty_Old_F250
35
11-14-2011 05:54 PM
65fordguy
1978 - 1996 Big Bronco
10-20-2011 09:35 AM
ctubutis
09-23-2009 10:26 PM
ctubutis
09-11-2009 11:58 AM
