Manual Transmission Swap c6 to NP435
I've been planning this for a long time, and I've finally got it started, and almost done!
Here's what came out:
And here's what went in:
Currently the transmission is in there and almost ready to go! I had a few issues with clutch size, as the 11 inch one I bought wouldn't fit my flywheel, so I had to go back and order the 11 1/2 inch one for an extra $100! Anyway, that's all solved now and the transmission is in! The clutch petal and all the linkage is installed as well, and it fits and works nicely.
Here it is:
This pic was taken in grandma gear, so it's as far forward as the lever has to go. I was worried about clearance for the shifter, and it fits, but not by much!
You can see my new parking brake lever in there as-well, it isn't hooked up yet, but it will be a nice improvement over my other one.
The only major things left to do are find a new section of rear drive shaft (and install it of course!, haha), re-install the exhaust and cut the tunnel cover to fit over my parking brake lever. After that, I'll be ready to hit the road!
Sam
Here it is:
Sam
I agree about the parking brake- a petal is just a pain for hill starts. The lever in the pics came off of a 1951 Ford F-6, I got it from 52 Merc on this forum, if you want you could send him a message, he might have another one. Keep in mind though, only the manual tranny's have mounts for it.
The shifter is actually fine, I took the picture with it in granny gear, so that's as far forward as it goes. I've got another shifter if this one doesn't work for some reason.
Sam
p.s. I think it's time to change my signature, this truck doesn't have a c6 in it anymore!
Sam
You might look for a lever off of an F500 or bigger truck. I've seen a few of them that came with one that mounts under the dash, I found one on a 1967 f250 4x4, but it looked swapped in (it was installed with sheet metal screws!)
Here's an old picture of it on my truck:
The only problem with it is it has no ratchet mechanism, and it doesn't mount at the best angle for pulling it.
Sam
Sam
I just left the auto column in there, popped out the shifter and called it good. I might replace it later, but for now, it should work just fine.
The hardest part of the swap was putting in the transmission itself, I'd recommend a transmission jack! It took all the muscle between dad and me to get that thing in there, and we're both pretty good sized. I woke up the next day and it felt like both my arms were about ready to fall off!
A tip I figured out for lining up the engine to the bell housing is using some threaded rod, about 6 inch long, thread a few pieces into the bolt holes on the engine, and then slip the tranny on there. It's a lot easier to get it lined up, and it was a lot easier for me to bolt the bell housing to the tranny to start with, I tried it with the bell housing on the engine and kept knocking the throwout bearing off the clutch fork.
Other then that, it was pretty straight forward, just unbolt the old, bolt in the new. The clutch and brake petals can be a bit of a pain to get around the column- but it's not that bad. It's easy if you pull the column out- but I'm too lazy to do that, so I wound up doing it the hard way!
So far I'm very happy with it, but I haven't been able to drive it yet because I don't have the correct drive shaft, hopefully I can find one this saturday.
Sam
Sam
same here, if it lasted since 75 in mine, i think its worth it.. plus i run 3:55 gearing and 35" tires so that helps some, if i towed heavier i would put 31" tires range E on tho.
