Mityvac...
Old Feb 18, 2010 | 10:57 AM
BillyBob69's Avatar
BillyBob69
Wow all that $$.... I used the "Mechanic next door" model. Got it for free and no cleanup afterwards. If his valve leaks...I just kick him to the curb and tell him to change his drawers.
Old Feb 22, 2010 | 10:18 AM
superduty4x4's Avatar
superduty4x4
Well I found the problem... big time leak on the passenger side. Now I just need to figure out where. I'm thinking about rigging up my air compressor to try and find where the leak is.
Old Feb 22, 2010 | 10:37 AM
PaysonPSD's Avatar
PaysonPSD
Can't your new MityVac also supply pressure?
Old Feb 22, 2010 | 11:00 AM
Visseroth's Avatar
Visseroth
What is ESOF? I can't for the life of me remember
Old Feb 22, 2010 | 11:58 AM
superduty4x4
I couldn't pump that little bugger fast enough to build either vac or pressure on that side, that's why I was thinking of the air compressor to pressurize it to about 10lbs and see if I can squirt some soapy water around to find the leak. Or I could order up the O-rings and hope its not the big seal in the knuckle.
Patrick- Electronic Shift On the Fly 4x4. You don't need to worry about it as I recall
Old Feb 22, 2010 | 12:11 PM
Visseroth's Avatar
Visseroth
ahhh, no I don't have to worry about it but none the less, good to know. Oh, BTW, if you have some time in the next few weeks I have some work to get done on my rig. I'll give you a buzz though and back to the subject at hand.
Edit: Oh, let me know if you would like a hand.
Old Feb 22, 2010 | 12:41 PM
superduty4x4
Yeah let me know. I have AE now too if you need to get it hooked up to a scanner for something.
Old Feb 22, 2010 | 02:24 PM
PaysonPSD's Avatar
PaysonPSD
Gotcha. Air compressor it is. Don't blow out the big seal.
I have a driver side hub vac leak. I replaced the outside black O-ring but that didn't help. That would have been to easy. I'm going to pull the hub and replace the yellow O-ring and cross my fingers. I have a set of O-rings for the passenger side as well. If the driver side isn't too difficult then I'll do the passenger side. If it's a PITA then the passenger side can wait till it starts leaking.
Good luck. I hope you don't have to replace the seal.
Old Feb 23, 2010 | 09:53 AM
superduty4x4
Pulling the hubs to replace the O-rings isn't that bad from my 1 experience. I need to call the local Ford dealer and see if they'll put me on a charge account since we don't have checks for our new bank account yet
Old Feb 23, 2010 | 11:56 AM
Kajtek1's Avatar
Kajtek1
Not too many modern cars can have brakes bleed with vacuum.
I failed to bleed brakes on my F450 with vacuum and had to use traditional pumping.
My Mercedes for example require pressure bleeding while applying 35 psi on the master cylinder.
That said about $80 buys you MityVac oil extractor that can be also used for brakes vacuuming. Can't beat big pump and 9 liter tank.
RoadJunkie
6.4L Power Stroke Diesel
Apr 7, 2010 10:58 PM
rsdjcarter
Jan 8, 2009 12:22 AM
77f2504by4
Garage & Workshop
Oct 1, 2008 07:55 PM
Mr.Ford 351W
Garage & Workshop
18
Feb 9, 2008 01:42 PM
blue beast
Garage & Workshop
Sep 23, 2007 09:35 PM
