Possible Vacuum leak???
Old Feb 8, 2010 | 11:56 AM
flyinlo24's Avatar
flyinlo24
I have a brand new issue that just started with my hvac system.. With the heater on full speed it works great, but when i step on the accel, i can hear the heater almost loose power. It sounds like the blower gets turned down but when i let off the accel, the power restores to normal. there is no change in the temp, just the speed of the blower? Any possible causes?
2003 Excursion V-10
flyinlo24
Old Feb 8, 2010 | 01:12 PM
rlh68050's Avatar
rlh68050
2003 Excursion V-10
flyinlo24
Check to see if the air flow is being directed to the defroster vents at the same time.
Old Feb 8, 2010 | 01:24 PM
Forest's Avatar
Forest
2003 Excursion V-10
flyinlo24
You didn't say--is yours a 4x4? If yes, it may be a vacuum leak to your hubs. Fairly common. Causes vacuum-operated internal doors to return to "normal" state. The change in blower pitch you hear is probably just the air being sent to a different output location.
centrix
Jul 26, 2016 05:32 PM
danielcoyle
May 31, 2014 06:46 AM
Super Econoline
17
May 18, 2013 08:34 PM
budthedog
13
Jan 16, 2009 09:29 PM
Motorcraftsman
Apr 21, 2000 10:47 AM
