6.0 woes
Old Feb 8, 2010 | 09:40 AM
critterf1's Avatar
critterf1
6.0 woes
HELP! I have an '03 F550 with the 6.0. Replaced FICM and INJ. two weeks ago and has been running great! Yesterday it took a dump, no codes, lots of white smoke and fuel dripping from exhaust. Any ideas?
Old Feb 8, 2010 | 09:44 AM
cartmanea's Avatar
cartmanea
If it is fuel dripping out, you probably have a cracked injector tip or a blown o-ring. If it is coolant dripping out it would be a blown EGR cooler. What are you using to read codes? Some scanners won't show you cylinder contribution codes, which could point you to the bad injector.
Old Feb 8, 2010 | 09:56 AM
critterf1's Avatar
critterf1
I have an OTC and it does show cylinder contribution. It had three bad injecters and a bad FICM and didn't run this horrible. I thought it was coolant too 'til I stuck my finger in it, it's diesel.
Old Feb 8, 2010 | 10:05 AM
cartmanea's Avatar
cartmanea
Its possible one of the new injectors was defective and the tip blew off.
Old Feb 8, 2010 | 10:32 AM
critterf1's Avatar
critterf1
DUDE, anything's possible!
Old Feb 8, 2010 | 10:50 AM
cartmanea's Avatar
cartmanea
I don't know what else you want. Fuel coming out the exhaust is usually an injector leaking, so you need to do a cylinder contribution test to see which one it is or a compression/balloon test to see which is leaking and then replace it.
Old Feb 8, 2010 | 12:27 PM
69cj's Avatar
69cj
I think he wants you to fix it without you even seeing it!
Old Feb 8, 2010 | 01:04 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
While alot of us around here are pretty helpful, we're NOT magicians
Old Feb 8, 2010 | 05:40 PM
mickpowell1967's Avatar
mickpowell1967
hit each exhaust leg with a ratec and you will find the bad hole usally the hottest
hole
Old Feb 8, 2010 | 07:00 PM
cheezit's Avatar
cheezit
check you oil level as well befor testing or driving. heavy deloution of fuel in oil will cause the engine to "run away" thats not fun
