engine question
Old Feb 7, 2010 | 03:16 PM
bren7176's Avatar
bren7176
engine question
would a 2003 t444e international engine fit a f350 and what mods would have to be made to make it work?
thanks
any help on this subject would a big help
Old Feb 7, 2010 | 03:43 PM
Franko72's Avatar
Franko72
Molon Labe
Im thinking the long block is the same, just all of the bolt on's will have to be changed...IE: the turbo, and belt driven accessories.
The experts will chime in soon...
Did you find a deal on one?
Old Feb 7, 2010 | 06:03 PM
bren7176's Avatar
bren7176
ya can get a real good deal on super low milage engine. just wondering if the injectors are the same as the fords or do those have to be changed out too, ya the experts on here should know what has to be changed out...
Old Feb 7, 2010 | 06:39 PM
Franko72's Avatar
Franko72
Molon Labe
Good deal.Not long ago I found a short bus with the PSD/Allison for a steal...but my budget wasn't on board.
Good luck, hope you get it.
Old Feb 7, 2010 | 09:21 PM
bren7176's Avatar
bren7176
ya hoping the guys on here will let me know what needs to be changed out if this will work the engine i got a line on has only 46k on it
Old Feb 8, 2010 | 01:16 PM
bren7176's Avatar
bren7176
still waiting on some feedback here... hopefully ..
thanks
Old Feb 8, 2010 | 03:51 PM
Franko72's Avatar
Franko72
Molon Labe
I find it hard to believe that no one knows.....
I would repost with a new name for the thread.....someone has to know
Old Feb 8, 2010 | 04:00 PM
Franko72's Avatar
Franko72
Molon Labe
Ok, here is what I could find....hope this helps some.
Same basic internals, built at the same time on the same assembly line, 444 CI = ~7.3L
Differences include:[*] Paint. The block for a PSD was blue, and the block for a T444E was black.[*] PCM. The powertrain control modules were located different and programmed different. The PSD was programmed for a pickup, with higher <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_14_0>horsepower</NOBR> and higher RPM. [*] Fuel filter. PSD fuel filter housing was much shorter so you could close the hood on a pickup.[*] Coolant filter. For several years, the T444E had a coolant filter installed on the assembly line, and the PSD did not. Somebody said they don't do that anymore.[*] Water pump. Different water pump, heater, and engine cooling system results is a different coolant specified for the PSD.
The T444E also still uses(used) a mechanical fuel pump and thus used a different camshaft with an additional lobe for the fuel pump.
Also, some of the various sensors are different due to the Ford vs. International wiring harnesses.
Both the T444E and Power Stroke used single shot (Standard AA Body Code) injectors until the '97/'99 model year. From '99 on, all injectors were Split Shot (AB &amp; AD Body Code; AB replaced AA on SN 4601095, AD replaced AB on SN 843990), unless they were the High Output (AC Body CodeThe basic block and heads are the same. But there are a lot of differences in the tacked-on things.
PCM. Save the one from your old engine and connect it to the 444.
Fuel filter/water seperator. Save the one from your old engine and connect it to the 444.
Water pump. Save the one from your old engine and connect it to the 444.
I'm not sure about the engine fan clutch, but I suspect you'll need to use the one from the PSD.
If any other parts look even a tiny bit different (other than paint color), then I'd use the one from the PSD. Altenator? Starter?
Old Feb 8, 2010 | 04:03 PM
bren7176's Avatar
bren7176
well that sounds good.. so the injectors should be the same and should be able to just transfer everything over and be good
Old Feb 8, 2010 | 04:08 PM
clem1226's Avatar
clem1226
just wondering do the T444E and the PS used in our trucks follow the same time frame/Sn for the PMR's or where all the T444E's forged?
superduty4x4's Avatar
superduty4x4
If it has the AC single shot injectors in it, you'll need a custom burned chip to run them properly. Accessories will have to be swapped (AC, power steering pump, turbo etc).
Old Feb 10, 2010 | 02:01 PM
bren7176's Avatar
bren7176
well have found some info but would still be good to hear if anyone has ever done this swap. I see the engines use the same injectors . but what else of the hard parts on the t44e would have to be swapped with the PS . and is the bell housing the same bolt pattern...???/ help help help
brendan
Old Feb 10, 2010 | 03:21 PM
Izzy351's Avatar
Izzy351
With your accessories, it should swap in. Core engine is the same.
Old Feb 10, 2010 | 03:58 PM
Franko72's Avatar
Franko72
Molon Labe
brendan
The bellhousing on your PSD will have an adapter for the 4R100. just swap it to the T444E
mars2424
Dec 20, 2014 07:38 PM
arnbobold
Flathead V8 & Flathead 6
Jun 12, 2008 06:58 PM
02GrayPowerStroke
Dec 13, 2006 05:04 PM
billexpedition
1983 - 2012 Ranger & B-Series
Jun 15, 2005 04:10 AM
hbtwarrior
Mar 19, 2004 08:07 AM
