compression ratio help
Old Feb 7, 2010 | 12:34 PM
obey_your_master's Avatar
obey_your_master
Alright fellas, I have a hypathetical question. What would the compression be on an certain fe that has C4AE-G heads, 360 flat top pistons (std), 390 rods, 390 crank, fel-pro head gasket?
Old Feb 7, 2010 | 10:24 PM
85e150's Avatar
85e150
Using this:
RSR Static Compression Ratio Calculator
and:
4.05 bore
3.78 stroke
rod 6.49
compression height 1.76
deck 10.17
combustion chamber 73.2
gasket .041
and NOT figuring the dish and/or valve reliefs in the piston:
10.04
Info from FE Cylinder Head I.D. and Application Chart
Note the chart shows a C4AE ----f, not a g. No g shown. See here re the "G":
https://www.ford-trucks.com/forums/928279-c3ae-g.html
http://www.kb-silvolite.com/assets/0...te_catalog.pdf
http://www.summitracing.com/search/B...c&autoview=SKU
+/- depending on the actual measurements, as all those numbers have a range in production and actual use.
If you have exact numbers, the calculator will give you a better number.
Old Feb 8, 2010 | 08:34 PM
obey_your_master
Ok, something's goofy with the calculator. I enter everything in and the final result is 1.35. Am I missing a step or what do I do with this number. If this is right, what does it mean?
Old Feb 8, 2010 | 08:46 PM
85e150's Avatar
85e150
You probably put 10.17 in deck height, which is what I did the first time. What they want is the piston-to-deck number, which I think is .030 in this case. I shoulda warned ya...
Old Feb 8, 2010 | 09:44 PM
obey_your_master
Ok, now that works better.
Frankinstine
20
May 30, 2014 02:46 PM
Riderman
33
Nov 26, 2009 08:42 AM
71LTD390
Apr 13, 2004 10:12 PM
gktbay
Aug 19, 2003 06:00 AM
dhickey
Oct 18, 2002 06:20 PM
