trans swap
Old Feb 6, 2010 | 09:58 PM
brians1979f100's Avatar
brians1979f100
trans swap
Ok, i have a 79' F100. It has an 84' F150 tranny in it currently. 4 speed. im wanting to convert it to a 5 (or 6 speed if possible)i have a 302 that i just rebuilt. Along with the rearend. what im wanting to know is what trans. would be best? I was looking into the M50D but i wans sure how it held under a lot of torque. so what would be best. I am aware of the conversion from manual clutch to a hyd. clutch and have a doner 95' F150 for that. along with the trans. choice what rear gears will need to be used? i have 3.93's currently. Thanks for the help.
Old Feb 6, 2010 | 10:08 PM
85e150's Avatar
85e150
Unless your 302 is warmed up quite a bit and unless you plan to side-step the clutch, the Mazda trans would work. The ZF will also work, and is heavier and has a lower first gear.
Depending on tire size, either would work fine with 3.73s or 3.93s or even 4.10s.
Of course, any used trans needs to have the shift forks inspected, and make sure the synchros still work, and that it hasn't been run low on oil.
The Mazda box has some plugs up top that leak--slowly, but enough over time to cause problems. Be sure those are replaced when you do the install.
This thread has ratio info, and links to other trans swap threads:
https://www.ford-trucks.com/forums/9...50d-truck.html
Old Feb 8, 2010 | 02:44 PM
brians1979f100
With the new tran. install i will not be very nice to it. so which will take more abuse?
Old Feb 8, 2010 | 05:12 PM
85e150's Avatar
85e150
ZF is a stronger trans.
Old May 26, 2011 | 11:36 AM
ocastari's Avatar
ocastari
brians : i have the same truck but mine is mexican , a dont now what tranny it have , i guess t-18 or similar because i cant run more to 120 km/hr , a saw that yours have ones from 84 f150, it´s really a swap the diference bettwen its .
when you changed the tranny what more things you needed change.
and sorry for my english is relaly poor i´m still learnig.
Old May 26, 2011 | 12:25 PM
LedheadELH's Avatar
LedheadELH
The ZF feels like a 4sp, with an overdrive gear. It's meant for F-350's. It's the strongest manual Ford offered. It will feel just like a T-19, but with a 5th gear.
The Mazda is much smaller/lighter duty but way more fun to drive. You can shift the gears a little quicker. The gear spacing feels alot different. Feels more like a car.
With a 2WD I would go with the Mazda. They say they are weak, but I disagree. You just have to know how to drive. Unless you have a real healthy motor, or a 4X4 with big tires they hold up fine......An try not to side step it TOOO much.
pgfords
Jun 20, 2011 10:31 PM
Hamburgerfella
Mar 6, 2011 07:22 PM
pfeifjob
Jan 12, 2011 06:04 PM
brians1979f100
Jan 2, 2010 09:36 AM
