Dead Battery
Old Feb 6, 2010 | 12:05 AM
amy_79's Avatar
amy_79
Dead Battery
Was wondering if anyone had an idea as to what would drain my battery over nite and cause my horn to go off by itself?
went to start it this morning and my headlight switch was sounding like it was shorting out (crackling and stuff) and then the lights started flickering. so i took my car to work instead and just left it. earlier tonite my horn started blaring on it's own. had to disconnect both batteries to shut it off. the one is completely dead and the other is still good, but has a lot of corrosion on the bottom, well on the dish.
be easy on me though.. still quite the novice with my truck .. lol
Amy
79 f150 4x4
camper special
351m
Old Feb 6, 2010 | 08:52 AM
Furyus1's Avatar
Furyus1
The first thing I would check is for bare or frayed wiring either under the hood or under the dash - sounds like you have something shorting out to ground. Since your horn is going off, I would start with the steering column wiring...
Old Feb 6, 2010 | 11:59 AM
amy_79's Avatar
amy_79
Thank you. we checked out the wiring and i think he figured it out. there was a lot of wires going nowhere.
Old Feb 6, 2010 | 06:03 PM
johnboy427's Avatar
johnboy427
Disconnect the positive battery cable and put a test light in between the battery and the cable, it will light up if you have a draw. Then start pulling fuses and see if the light goes out, if it does you have located the circuit giving you trouble. I wouldn't stop there I would check them all you could have more than one. If you have some after market stuff installed the light might stay on even with all the fuses out then try unhooking them too.
-Johnboy
Old Feb 9, 2010 | 06:09 PM
evanch123's Avatar
evanch123
Battery Drain
I have a 1982 f250. It has been sitting for 15 years. I got it running and installed a new interstate battery. I threw the battery in and it cranked right up. I let it sit overnight and it wouldn't crank in the morning? Where should I start to get this drain figured out?
-Evan
Old Feb 9, 2010 | 06:20 PM
Furyus1's Avatar
Furyus1
-Evan
I would start with the procedure johnboy427 posted above.
Old Feb 10, 2020 | 11:32 AM
hturner12's Avatar
hturner12
Jacob hope yall work it out money will destroy a relationship fast.
When you own a Caddy the tag office knows you have money lol.
We got the livingroom floor painted. Got the old fllor covering off the bathroom founf some rot by the tub
Old Feb 11, 2020 | 02:26 PM
mark a.'s Avatar
mark a.
I would use a multi meter. A small draw won't light a test light.
old broke prospector
Mar 24, 2013 02:05 PM
teardropty
Escape & Escape Hybrid
Oct 4, 2011 08:50 PM
amy_79
Oct 2, 2010 10:30 PM
amy_79
Jan 20, 2010 04:15 PM
sleddog60
May 18, 2009 09:29 PM
