9" rear end
Old Feb 5, 2010 | 05:40 PM
drfarns's Avatar
drfarns
9" rear end
I have a 1954 Panel Truck project and was wanting info on what type 9" rear end to use. What modifications would be necessary, etc.
Old Feb 5, 2010 | 06:26 PM
norvillebob's Avatar
norvillebob
1948 through 1960 Ford F-1 and F-100 Rear Axle (differential) Swaps .: Articles
bob
Old Feb 5, 2010 | 07:37 PM
bobj49f2's Avatar
bobj49f2
Here's a good description of what it take to do the swap in a '48-52 truck, I would imagine it's got to be pretty close to the later models:
Axle swap
Old Feb 6, 2010 | 01:16 AM
1oldtimer's Avatar
1oldtimer
i have one from a '71 truck in my '54 panel. i didn't do it but it looks like a direct bolt in. the spring perches are smaller then the '71 so i bought the tie brackets from mid fifty (the '71 uses 2 1/2" wide spring and the '54 is 2" wide) and you'll need new shock brackets (the shocks are on the front of the '71) also from mid fifty. not sure if the u-joint is the same though.
Old Feb 7, 2010 | 07:07 PM
Jetman's Avatar
Jetman
Look arond the savage yards!
The nice thing about this swap is that the rear end from a 67-71 Ford pickup is a direct fit. You will need to have the drive shaft fitted by the pros. There are plenty of positive traction units in the 67-71 ford truck in the savage yards. I picked up a rear end from the savage yard in good condition complete with a positive traction third member and 3.70 gears for $200.00. I went around look under the trucks until I saw the tag with the "L" between the numbers which signifies the locking differential. Best wishing and happy hunting.
Mike W
Mar 16, 2016 11:36 AM
weldworks54
Jan 31, 2012 08:43 PM
gary534
Jul 1, 2006 04:34 PM
jambroson
Apr 2, 2004 12:46 PM
wabadman
Jul 9, 2000 01:43 PM
