Sponsored by: Real Truck
2004 Super duty headlights
Old Feb 4, 2010 | 10:50 PM
skyoung's Avatar
skyoung
any way to make the headlights brighter on my 2004
Super duty 6.0?
S-K-Y
Old Feb 5, 2010 | 01:19 AM
da-bees's Avatar
da-bees
Best and most expensive is buy upgrade kit from most parts stores and some sponsers of this site.
Second choice is search this forum and tech folders for "BriteBox".
The choice for those of us who are thrifty is found in tech folders and at S&S Diversified's web site. Search "foglight fix" that shows a 30 minute job that lets fog lights be on with high beams.
Old Feb 5, 2010 | 02:54 AM
Roadfind's Avatar
Roadfind
Not hijack this tread but !! is there any way to ajust the headlight . Even before I installed the leveling kit the beam pattered is too high . There has to be a way to ajust the pattern . sorry,,,,
Old Feb 5, 2010 | 04:40 AM
flamebuster's Avatar
flamebuster
yep it is pretty simple, there is a adjusting screw I think on the top, ah heck now I gotta go out and look on my truck.It's been a while since I adjusted mine..I'll get back thou....lol
Old Feb 5, 2010 | 07:23 AM
rjfetz1's Avatar
rjfetz1
PIAA makes the best bulbs if you can afford them. Silverstar is better than stock. 4 KC Daylighters...problem solved I would go with adding driving lights before any other kit myself. That's my next purchase, just need to figure out how I want to mount them.
Old Feb 5, 2010 | 09:02 AM
VEECON's Avatar
VEECON
your best option is to do a hid conversion kit, just make sure you do it the proper way.
Old Feb 5, 2010 | 09:39 PM
flamebuster
OK I checked mine on the fender side of ea. headlight at the back of the light housing half way down the housing is a screw that takes a T-20 driver. or you can use a metric socket not sure the size. Turning this screw will move the headlight beam up and down.
On the inner side of the light about level with the top of the light housing is the same size and type of screw turning this one will move the headlight beam left to right.
Old Feb 6, 2010 | 01:13 AM
Roadfind's Avatar
Roadfind
Thanks Doug for getting back on the recon work here . I'll get on this tomorrow, it just bugs the heck outa me not having the lights doing the best they can be doing . ollllo
Old Feb 6, 2010 | 01:57 AM
flamebuster
glad to help and I know what you mean I am picky about where my lights are pointed too.....
joe2433
Electrical Systems/Wiring
Nov 13, 2012 07:31 AM
Docdor
May 7, 2008 12:42 PM
Studenut65
Nov 5, 2005 10:42 PM
