pcm
Old Feb 4, 2010 | 06:45 PM
1bigjoe's Avatar
1bigjoe
we'er expecting as much as 20 inches of snow, it's for days like this. that i have this truck----so frustrated
Old Feb 4, 2010 | 06:55 PM
WarOzz's Avatar
WarOzz
Well since none of the auto trany experts seem to be around yet today I went ahead and did a little research on google. I found this tech bulletin on water intrusion into the MLP
This bulliten refers to ford part number F5TZ-7A247-A sensor rebuild kit... when cross referenced to the newer ford replacment number you get MOTORCRAFT Part # SW5978... cross reference that a bit more to an autozone part that comes up as a neutral safety switch. I find it odd to me that a neutral switch could cause the problem your having but my experience with auto's is strictly on C6's and old chevy turbo 350's.
This switch at autozone is fairly cheap at $36.00
Old Feb 4, 2010 | 09:01 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Tach not working, tranny in limp mode.
MLPS or TPS is not responsible for his problems in my opinion.
How the signal gets from the IP drive gear, to the tranny PCM, and from there to the tach is where I am betting his problem is.
I have no experience with the E4OD in an IDI, so I am only guessing with my answers.
If someone with an E4OD behind an IDI can tell Joe how the tach wires run on the E4OD trucks, I thnk that would get him going.
Joe, if you go to the user control panel, then edit signature, then enter your truck info, it would help people see what we are working on.
That helps eliminate many wrong guesses.
Old Feb 14, 2010 | 03:17 PM
phantom 309's Avatar
phantom 309
i had this problem with mine. you need to replace your cluster.
Old Feb 18, 2010 | 09:43 PM
z scpaes's Avatar
z scpaes
BIGJOE, the PCM is coded to the truck, lots of different codes for different models and years. you cannot get a used PCM to work in your truck unless the numbers on the side of the PCM are exactly the same. you also cannot buy a new one unless you take the old one to the supplier/dealer. I had mine rebuilt.
Borgia
Oct 14, 2016 06:21 PM
Jmudweiser
Sep 13, 2016 05:02 PM
cwstanley
6.4L Power Stroke Diesel
May 1, 2012 09:07 PM
wildstang
Sep 1, 2009 09:27 PM
