Alignment
Old Feb 3, 2010 | 09:26 AM
mxfam4x4's Avatar
mxfam4x4
Alignment
Hello from the sierra's! I have a 99 f-250 4x4. I recently replaced the upper & lower ball joints, had 4 new 315/75r16 TOYO M/T tires mounted
& it pulled realy hard to the right. So I scheduled an alignment at Les Schwabbs in Gardnerville Nv. After 4 hours of waiting for new bushings & a complete reconfiguration of the castor,camberand toe in and it still pulls to the right and the wheel weights were hitting my front callipers. So back to the shop after only 5 minutes. They reballanced the front wheels and a different tech took it for another test drive. He agrees that it is still pulling to the right & also that it is wondering at highway speed. So I rescheduled it for next Saturday to have the manager do the alignment this time as the tech says it is within specs and there is nothing more he can do. Any ideas as to why it is so hard to align this truck, past experiences or suggestions you may have for me would be greatly appreciated.
Old Feb 3, 2010 | 09:31 AM
riverrat41's Avatar
riverrat41
Not sure but I would stay on their ars untill they either get it right or give you a refund on the alighnment.Then you can take it somewhere else and see if things change.
Old Feb 3, 2010 | 10:12 AM
Bowie's Avatar
Bowie
I am no help, but I am experiencing wander issues too.
Bump
Old Feb 3, 2010 | 10:51 AM
FreeDevin's Avatar
FreeDevin
subscribing...I'm interested to see how this works out
Old Feb 3, 2010 | 11:30 AM
mxfam4x4's Avatar
mxfam4x4
Bowie, I was experiencing the wander prevoiusly & thats when I found the lower ball joints worn out. That was the fix for the wandering & it did. But then the pull to the right started & I figured either I had put the shim in incorrectly or as a result of replacing the ball joints I had changed the alignment on the truck. When they first put it on the rack yesterday they said it was within specs. I argued that it was pulling to the right & I was seeing cupping only on the inside of left front tire only. I thought It was probably toed out and that the right front caster was out as well. Anyway here we are now. I will let you all know how this turns out good or bad!
Thanks, MXFAM4X4
Old Feb 3, 2010 | 11:48 AM
husker's Avatar
husker
One other thing to try is to swap front tires for the rears and see if it goes away. You may have a bad tire. I've had that happen. It can even happen with brand new or near new tires.
Old Feb 3, 2010 | 01:13 PM
mxfam4x4's Avatar
mxfam4x4
Swapped tire front to back , Thats why wheel weights hit front calippers.
Old Feb 3, 2010 | 01:52 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
As an alignment technician, I can say with absolute certainty that "within specs" is a lazy-man's way of saying "It's close enough.".
Unless the actual measurements are right on or adjusted to compensate correctly, it's not aligned.
For a 99 Super Duty with 35x12.5 tires, I would set the camber at +1.0 degrees on the left, +0.75 degrees on the right. I would set caster at 4.5 degrees on the left and 5 degrees on the right. I would also set toe at +.15 degrees.
Specs for camber are -0.75 to +1.25 "perfect" is +0.25
Specs for caster are +1.5 to +5.5 "perfect" is +3.5
Specs for toe are -0.220 to +0.280 "perfect" is +.03
Larger tires (on wheels with less backspacing or more offset) are going to try to "pry" the tires outward while driving down the road so I'd try to stay with a more positive toe to combat this.
The truck will pull to the side with the most positive camber. It's customary to give the truck a bit more on the left to combat road crown effects.
The truck will also pull to the side with the least positive caster. It's customary to run half a degree or so less caster on the left to aid in road crown pull as well.
Hope this helps.
Old Feb 3, 2010 | 01:58 PM
DieselCamper01's Avatar
DieselCamper01
That is terrific info Cody. Reps
Old Feb 3, 2010 | 02:45 PM
redfire42's Avatar
redfire42
Is it a 4 wheel alignment? I heard the rear can get out of wack and cause a pull in the front.
Old Feb 3, 2010 | 03:03 PM
mxfam4x4's Avatar
mxfam4x4
Cody, dealer readout as follows
left right
actual before specified actual before specified
0.6 0.0 -0.8 1.3 camber 0.6 0.1 -0.8 1.3
3.9 4.6 1.5 5.5 caster 4.1 3.9 1.5 5.5
-0.07 -0.04 -0.13 0.13 toe -0.09 -0.08 -0.13 0.13
cross camber 0.0 -0.1 -1.0 1.0
cross caster -0.2 0.7 -1.0 1.0
total toe -0.16 -0.13 -0.25 0.25
I will be at dealers on Saturday morning with your specs in hand.
Thanks again!!!
Old Feb 3, 2010 | 03:26 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
left right
0.6 0.0 -0.8 1.3 camber 0.6 0.1 -0.8 1.3 I'd leave the camber alone.
3.9 4.6 1.5 5.5 caster 4.1 3.9 1.5 5.5 Increase both casters. Make the LF .5 degree less.
-0.07 -0.04 -0.13 0.13 toe -0.09 -0.08 -0.13 0.13 The toe is -.07 and -.09!?!?!?
That definitely is going to cause a wander. It needs to be about +.07 and +.07 (+.14 to +.2) if it's an individual L/R measurement.
cross camber 0.0 -0.1 -1.0 1.0 This looks good. The cross camber is fine.
cross caster -0.2 0.7 -1.0 1.0 Cross caster needs to be a bit more...like -0.5 to -0.7.
total toe -0.16 -0.13 -0.25 0.25 Negative toe is BAD!!! Especially with larger than stock tires!!!
Thanks again!!!
Take these measurements with you:
Camber:
L +0.6
R +0.6
Caster:
L +4.0
R +4.5
Toe:
L +.07
R +.07
Total +.14 to .2
I wouldn't recommend these measurements on a stock-tired truck, but 35x12.5 tires are kind of a special needs case.
See if they agree with these numbers.
Old Feb 3, 2010 | 03:48 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I wouldn't say that a "pull" would result. More of a constant drift or off-center steering wheel.
If the rear is truly out of whack, as would be the case with a bent axle tube, then it's not repairable. However, rear camber and toe readings are given on alignment machines as well as "thrust angle" which is the angle that the rear wheels are trying to push the vehicle (dog tracking).
Old Feb 3, 2010 | 08:11 PM
redfire42's Avatar
redfire42
Thanks for clearing that up.
Old Feb 10, 2010 | 05:22 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
What is the verdict? Was another alignment performed? How does the truck drive?
